Well the wreck has been out the back for a month now and i've decided to wreck it.
Its a 97 series 1, white pearl colour.
I'll start with whats not for sale.
Parts not for sale,
Engine accessories e.g turbo, exhaust, intercooler piping
Dash trims
Cluster
Floor mats (maybe)
taillights
So with that listed, everything else will be up for grabs.
Engine is rb25det with auto box (prefer to sell as complete, but may seperate depending on price) looking around $3000 together
done 118k km's service every 5k using castrol SLX professional oil, timing belt and water pump replaced at 100k service, only ran on 11psi, i was more about fuel economy than thrashing everywhere.
Trans in great condition, no problems at all.
Interior e.g seats, door trims, console and other trims
exterior panels still good are averything except front bar, bonnet, rhf door and guard, all others are still good.
Any other parts let me know as there is heaps and will take ages to list.
Here is a the most recent photo, will post up more in the next couple days.
Can post up pics of certain parts on request.
Will organise prices on request.
All parts are still on car so allow time for removal.
Also car is located north of adelaide towards Gawler.
Inspections welcome.
All enquiries via post, pm, or email at [email protected]
Cheers.
Jarrad.
https://www.sau.com.au/forums/topic/259481-eoi-wrecking-series-1-stagea/
  • Replies 42
Na sorry adam wheels aren't for sale.
Will also be keeping brakes and suspension as they will go on my next one, but i do still have standard brakes and suspension if anyone wants it.
Sunvisors are in ok condition, have some staining (haven't tried to clean) will be keeping drivers A pillar trim as will be moulding a gauge pillar holder to it.
Will pm ya pics of sunvisors micah.
Some more pics.
HAve more pics but its taking its sweet ass time to upload.
Can take pics on request.
Cheers
Cheers
Thanks for that. As a matter of interest, have you checked out mearcat.com(.au?) for stagea specific guage pods?? I have both the a-pillar one, and the clock replacement pod: fit and finish is very good... Just food for thought (because I really need your a-pillar! :) )
Hey mate,
after a steering wheel, don't need the airbag bit. And also the passenger side handle that lets the rear seats fold forward(the one in the boot). Hmmm, not sure what else.... could you pm me some prices, cheers
finally got my new car, and has come with some parts which was going to keep from my old car.
So more parts for sale.
cargo net
pull out privacy blind (baige coulor)
can post up pics but everyone knows what they look like.
carbon fibre look trims for dash and console
carbon fibre look door switches for all doors
carbon fibre look shifter with button on top
carbon fibre look instrument cluster
unsure of market values so throw some offers or if someone can post some figures of what they're worth.
cheers.
Jarrad.
cargo net
cheers.
Jarrad.
Prices for these please?
    • How much have you lowered?  I had 350Z springs in the rear and was able to pull the camber into factory spec with the factory arms on the rear, obviously the front ran negative camber as it isn't adjustable, but rotating the wheels regularly evened out the wear.
    • Either the installer needs to come back, you need an auto electrician, or you need to learn automotive electricals yourself.   First step Id look at is where that big thing came out of, is there still things unplugged at that location? Maybe they just forgot to put a relay in or something?
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
