Hi guys, I'm up for a new clutch, I've read a few threads on clutches and im probably leaning towards a Exedy Organic HD clutch. The car is a R33 with around 190rwkw. Ive tried ringing Jim Berry like 5 times on different days but havent been able to get a hold of him (he said he would call me back and hasnt) to see what kinda clutch he can offer me, I'm done chasing him so I'll probably just go for the Exedy HD or should i go for the Exedy cushion button? The car is a daily driver so it needs to be driveable through heavy traffic.
I will probably do the clutch change my self but just wanted to ask what bearings are usually changed when changing the clutch? Cause at the moment I've got like a cricket sound in the gearbox when the clutch is not pressed in, as soon as i press it in a little bit it goes away. Also when i press the clutch pedal sometimes it sqeaks... so what should i be looking at when i change the clutch? Any help appreciated.
https://www.sau.com.au/forums/topic/259526-need-a-new-clutch/
The organic should be fine for the power your running, I had an Exedy 5 puk HDB in mine and it wasn't too undrivable at all. It did however toast itself and semi melt itself to the flywheel the other week. Thats after 12,000k's and apparently there was no free play.
The kit will come with a thrust/throw out bearing, which is the one causing your noise I think. It is the one that the clutch fork pushes against the pressure plate.
The sqeak is most likely where the fork pivots off the pivot ball inside the bell housing. carefully add grease to the pivot ball, don't get any on any clutch component or flywheel. Probably a good idea to have the flywheel machined at the same time.
I have an organic which is rated to 240kw (which is what i'm running and its fine). Perfect for heavy traffic.
As well as the throw out bearing that'll you'll get with the clutch kit, you also want to replace the spigot bearing which sits in then end of the crankshaft (and supports the gearbox's input shaft. You'd be crazy not to do it while the gearbox is out. Its a sintered bearing so you fill it with lubricant before you install it. Just search for spigot here to find more info.
I read a few threads on this spigot bearing and damn its not the easiest thing to get out...but i'll try packing grease inside to force it out.
And definetly getting the flywheel machined, thanks for the replies.
That reminded me, woulda totally forgotten when put everything back together, just ordered one. Cheers!
I had a sports organic and it didnt last too long, and i wasnt ridiculously harsh on it but there was a bit of 'spirited' driving. Put is this way, the standard clutch lasted longer.. with only slightly less mods (being frotn mount and boost)
I now run a full monty from jim berry and its top notch, never slips or reaks like the excedy ones do, and was even easier to press than the excedy, it can be a bit bitey but you get used to it - i use it as a daily driver.
I highly reccomend calling him again, the number i get him on is 07 38479999
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
