Hi guys, I'm up for a new clutch, I've read a few threads on clutches and im probably leaning towards a Exedy Organic HD clutch. The car is a R33 with around 190rwkw. Ive tried ringing Jim Berry like 5 times on different days but havent been able to get a hold of him (he said he would call me back and hasnt) to see what kinda clutch he can offer me, I'm done chasing him so I'll probably just go for the Exedy HD or should i go for the Exedy cushion button? The car is a daily driver so it needs to be driveable through heavy traffic.
I will probably do the clutch change my self but just wanted to ask what bearings are usually changed when changing the clutch? Cause at the moment I've got like a cricket sound in the gearbox when the clutch is not pressed in, as soon as i press it in a little bit it goes away. Also when i press the clutch pedal sometimes it sqeaks... so what should i be looking at when i change the clutch? Any help appreciated.
The organic should be fine for the power your running, I had an Exedy 5 puk HDB in mine and it wasn't too undrivable at all. It did however toast itself and semi melt itself to the flywheel the other week. Thats after 12,000k's and apparently there was no free play.
The kit will come with a thrust/throw out bearing, which is the one causing your noise I think. It is the one that the clutch fork pushes against the pressure plate.
The sqeak is most likely where the fork pivots off the pivot ball inside the bell housing. carefully add grease to the pivot ball, don't get any on any clutch component or flywheel. Probably a good idea to have the flywheel machined at the same time.
I have an organic which is rated to 240kw (which is what i'm running and its fine). Perfect for heavy traffic.
As well as the throw out bearing that'll you'll get with the clutch kit, you also want to replace the spigot bearing which sits in then end of the crankshaft (and supports the gearbox's input shaft. You'd be crazy not to do it while the gearbox is out. Its a sintered bearing so you fill it with lubricant before you install it. Just search for spigot here to find more info.
I read a few threads on this spigot bearing and damn its not the easiest thing to get out...but i'll try packing grease inside to force it out.
And definetly getting the flywheel machined, thanks for the replies.
That reminded me, woulda totally forgotten when put everything back together, just ordered one. Cheers!
I had a sports organic and it didnt last too long, and i wasnt ridiculously harsh on it but there was a bit of 'spirited' driving. Put is this way, the standard clutch lasted longer.. with only slightly less mods (being frotn mount and boost)
I now run a full monty from jim berry and its top notch, never slips or reaks like the excedy ones do, and was even easier to press than the excedy, it can be a bit bitey but you get used to it - i use it as a daily driver.
I highly reccomend calling him again, the number i get him on is 07 38479999
 Share
    • Big claims here.  Any links up on the website ?
    • If your HP goal is reasonable and you are not drifting. Buy a new R34 box.  If the above is not true, buy a wrecked R33 box and put a gearset in it.  CD09 are not as strong as you think and the cost of / mess around of the conversion puts you in gearset territory.    Also the deal above is awesome,, get that
    • Just got back from a little hands-on with a G58 Baron....I was thinking about this... ..best I can figure it, that pinny was tail-ended ...I didn't really think about the wiring, because all that mattered was the tank and pump cradle (I think I mentioned the pump itself I couldn't vouch for)...which didn't matter, as you said you'd be replacing the pump anyway.... ...'for some reason'....and I imagine this is the panel shop's doing... they've replaced the cradle wiring with a metre of 7-core trailer loom, and attached the loom plug (from a different car) to that. The actual cable run from the top of the pump cradle, to fuel pump harness end in boot, is maybe 60cm in length...so I've no idea why they did this... ....the connector in the boot of the pinny, is not going to help you here...because in theory, it should still be present on your car. On top of that, because they've done what they did, we have no idea which colours of the trailer cabling, have been connected to what on the fuel pump cradle (pump +/- , shield, fuel guage/low-level senders)... ...this means, best approach is to remove the pump cradle, and re-work it now ...not later. That is, if you were going to replace the pump, do it, replace the soft lines at the same time...and sort the wiring out (replace that trailer cable with the wiring loom off your old cradle)...
    • Well, maybe not. The main feature of Chinese manufacture seems to be incredibly variable quality, coupled with an apparent willingness to find a way to see even the stuff that fails QC. So the military could still take the cream of the production run and somehow sell the "sellable but not really useable" stuff to the stupid round eyes on the other side of the world.
    • Have you adjusted the clutch pedal rod? You can wind it in to shorten it. Just can be a cnut to get to.
