1993 R32 GTS-T Black
Just hitting 85,000kms. Car has been meticulously maintained and looked after. Body is ding and dent free its never parked next to other cars. Interior is immaculate, no peeling steering wheel etc.
Motul 8100 engine oil - every 5000 + genuine nissan oil filter.
Motul 90pa - After every track or 10,000
Royal Purple - Gearbox every 15,000
NGK Plugs every 10,000 to 15,000
Car has never been boosted, it has been built for reliability and handling rather than uber power. It will go lap after lap after lap at the track/drift whatever you want to do. It even works damn well as a daily driver. This car can be setup to do whatever you want, drift or track then drive right back to the metro sydney with no problems.
First owner in Aus, was a auction grade 4.5. Unfortunately there is not enough room at home and it has to go - to a good home only! Sorry no splitting and pillaging for parts. This is an awesome car and deserves a good home damn it!
Outside
GTR front bar
Phillips HID KIT
GTR rear wing
Inside
Pivot Digital OIL/Water temp with fan control
Blitz Dual SBC controller - limits set at .98bar
Greddy Exhaust Gas Temperature gauge
Handling
GAB strut bars front and rear
GTR 32 Wheels and one set of standard gtst wheels (much easier for new rubber installs)
KAAZ 2way LSD
Tomei HICAS Lock
Whiteline Adjustable Sways
Cusco front upper arms
Adjustable castor rods
Apexi N1 Coilovers- Height Adjust + Compression adjust
Urethane rear subframe bushings.
HKS Pillowball mounts for the rear
Engine
HKS Pod
HKS Dump Pipe
Apexi N1 Front pipe
Kakimoto Catback
HKS GTR 32 Remote oil Cooler - Keeps the engine oil stable around 85 and changing oil filters has never been so much fun!
GTR33 Fuel Pump
400hp Clutch Disc - super easy to drive.
Odyssey battery
Price: $13900.00[/b][/i]
Please PM for more information or contact information.
post-1393-1236124582_thumb.jpg post-1393-1236124593_thumb.jpg post-1393-1236124649_thumb.jpg
post-1393-1236124660_thumb.jpg post-1393-1236124670_thumb.jpg post-1393-1236124680_thumb.jpg
https://www.sau.com.au/forums/topic/259536-1993-r32-gts-t-black/
  • 6 months later...
  • 3 weeks later...
one of the hottest 'stock looking' R32's ive EVER seen, that thing is an absolute beast and will sell well mate! good luck!
thanks champ.
it's not trick photography either, it is very very clean inside and out.
  • 1 month later...
    • 2 does "sort of" applies, maybe......but looking at what parts would be needed for the swap to get engineered, registered, and insured, and basically that's everything under the car, the modifications the make it legal would be problematic and horrendously expensive, all for a street car that just cruises around and hits a few twisty roads on the weekends Also, from looking at the NSW rules and Regs, with all modifications that is required just to make the car safe and not twist itself to pieces, and then actually get registered for street use, may still be impossible nowadays As for 1, when you add in a fresh engine, fresh transmission, rear cradle and diff, tailshaft, suspension, brakes, cooling, and all the other fabrication required, your probably looking at up to $100k to do it right, all for a 20 year old MX5 that is over engineered and you would never be able to actually use the power it has on the street, much like your beastie, which I love, but you actually track that thing and can use all of its powers in anger, in a safe environment  Hell, the old Bogan Cruise Ship had more power than I could use on the street, and in hindsight, I went a bit silly on that thing, it didn't really need the 500hp it had for what I actually used the car for, it was fun, but basically unusable on the street if you value your licence  As for cams, yeah, I'll probably book it in for them to get installed and tuned soonish, like next month after MX5 Mania are back at work....... and yes, I've already sent a email to bin the turbo quote and quote instead to install cams and a new Fluidampr balancer that will suit the 2.5 better than the OEM 2.0 balancer that is swapped over for the 2.5 install, as the balancer needs to get pulled to time the cams it's a while your in there sort of thing I did think a bit about flex fuel for a laugh, but being na, and no where really around locally anymore to get E85, I've binned that idea, so no sweet sweet corn smells are set for the car I wish E85 was more of a standard fuel, it's better for the environment, better for tuning, plus that sweet sweet smell we all love As for fitting in the family, that's not needed, as everyone in the family already owns a car that can seat 5 humans comfortably enough, the MX5 is "my toy" As for buying a car that is already built, nah, I would rather pick and choose my parts, I enjoy the process, and in the big picture, the additional cost is well worth the enjoyment, and the occasional frustration, I get out of doing it, albeit with other people spinning the spanners, and me, just paying the invoice 🤣
    • Excuse me, but 2) does apply 1) Would also apply if you consider how much is spent in the alternatives. Also there's the option of 3), buy one pre-built that you can put your family in (it's me, it's my car)   That said, I went on a ~500km drive the other day. I didn't use anything more adventurous than 3rd/4th gear at about ~3000RPM and 50% throttle and I was going as fast as anyone has any sense doing on a public road, with enough grip to the point where I didn't want to go any faster. I was obviously under the limit of the current car etc etc. MX5 with 2.5 N/A to achieve the same speed would be more fun for any road scenario. Maybe consider cams. I wouldn't boost it. The use case is just not there and it won't actually make the car more enjoyable unless you really do plan on wringing gears from 1st to 3rd (at least) at 100% WOT on a public road to 150+kmh.
    • Great if: 1. You had all of the money for everything else that is required  2. Lived in a country where you could actually do this and drive it legally on the road Sadly, neither applies to me As for the turbo, I am having second thoughts, mainly for engineering/registration legality reasons and insurance  Not saying I've finished doing stupid things that I probably should do to the MX5, but boost, and V8 engine swaps isn't on the cards Strange, but true
    • I like this page, better than that silly turbo kit   https://v8roadsters.com/product-category/engine-conversions/engine-conversion-lsx/engine-conversion-lsx-nc/
    • That would be my Shoei helmet
