G'day pals,
I have just manage to aquire a rubby duckie zodiac boat! its a sweet fun little thing that im planning on strapping to the roof bars of my stag with the Ryno roof racks i have, i just have a slight concern with the weight on the roof and if the bars can handle it. Id say the weight of the boat is probably about 60kgs or so... opinions?
:D add one more use to the already huge list for the stag... its a boat trailer!!
https://www.sau.com.au/forums/topic/259541-roof-bars-maximum-load-capacity/
The bars are very solid and heavy, 60kg is nothing spread over both bars, considering there are 6 mounting points. I would have no hesitation putting 2-3 times this on the roof.
Yep I have had excessive amounts of particle board and timber on my roof - at least 300kg...makes it sway a bit on the corners!
I dont know what the load rating on those bars are.....but Kiwi, all i can say to that is OMG thats alot!
rb26stagea here: I'm on a mate's computer... I have removed the roof bars from my car, and I can tell you they are extremely solid: they are steel underneath the plastic coating - you should have no issues with a small inflatable on them. I estimate they weigh at least 15kg each. worst case, if you were to bend them (VERY unlikely), I have a set sitting here that I am willing to part with. That said, you should not have any issues at all...
i'd dare say he'd be more concerned with distorting the roof etc with excessive loads than bending bars
I've had lots of building material on mine- timber, cement sheets, villaboard etc easily 200kg without a problem.
I think you will be limited to the safe loading capacity of the ROOF RACKS that you attach onto the roof bars than the roof bars themselves.
.......I have removed the roof bars from my car.........
Hey Green Ghost,
Have you replaced the gaps left by removing the r.racks with something?
I've heard people talk about getting a plastic molded strip or something thats
made for the stags...you got something like this???
I would mind removing mine, don't use them.
Pete
    • Adjusting the idle screw is usually (emphasis on usually) just covering up deeper issues. Stuff like the cold start valve not closing properly. Throttle shaft seals on the way out. Coolant temp sensors getting out of spec. Coolant temp sensors especially can be a bear to diagnose because they can fail subtly. My dad just spent weeks chasing down his high idle. He cleaned the coolant temp sensor and everything but the resistance curve just drifts over time and if it's been 20+ years they also get super slow to respond as well. Has a massive effect on fuel economy as if it's off the ECU is going to run richer and command high idle for far longer than it should otherwise.
    • How old is the battery, it's more likely your battery is on its way out.
    • I reckon you'd get 90% off. My washer doesn't get between spokes very well. Haha! I love my Gerni!  Argh! Steam cleaning has its place for sure.
    • Hey all, I did a voltage test with the car (video attached) not running for 3 days. And here is some interesting stuff: - Battery voltage is 12v (I had the key in the ON position) - Drops to 9.76v while cranking then quickly goes up to 14.5v - You will notice there was a sorta slow start but not as slow as it usually is. - Idle surprisingly was better at just over 1,000rpm instead of 1,100 rpm. - I turned on the A/C, radio and headlights in the video and the voltage remains the same - I haven't cleaned the grounding wires on the chassis yet, that's next. - Battery drops to 12.6v when I turn off the car and wait a bit Seems like I might have a parasitic draw? I do have an immobiliser system which does drain the battery more of course but was wondering if there is anything else I should be looking at fixing? Does the ground wires on the chassis have anything to do with the low 12v?        SAU.avi
    • My lord that is some low oil pressure as minimum in the manual! I guess the big part will be seeing how it changes as the engine gets more spirited use.
