Hey all,
As i work with a mandrel bender on a daily basis, i was talking to my boss the last day or two and was chatting about all our left over bends that we have lieing round and we thought bout just getting rid of them cheap to guys interested in them for like cooelr piping and exhaustt systems. Generally i get a lot of 3" alloy and steel, both perfect for cooler piping and definately steel for exhausts, of which i had my dump pipe made for about 30 bucks. We bend from 40mm tubing up to 4", but generally the most used is 3", 60mm and 50mm. 60mm alloy is perfect for R33/32 intercooler piping which is what i used on my car, 50mm for some like 180sx's coming off the turbo etc and 3" is good for the outlet side of the cooler going to throtttle body on say SR20's and so on or really good for GTR's and gtst's running larger turbos and what have you. I try and put aside as much of them as i can not to waste them, and at themoment i have about 15 odd 3" mandrel bends ranging from about 45, 60, 70, 75, 90 degree bends in steel, in alloy there is a handful or 3mm wall 3" 90 degree bends and a few in 4.75mm heavy gauge piping in 90's aswell. There's a couple of 60mm 90's and a heaps of 50's. On a weekly basis we usually have this many lieing round constantly rotating between sizeing depending on what i am bending at the time for different jobs. So if anyone is interested PM me if you have any size of what you need, i think he was saying about 15-20 bucks each or something which is damn cheap cos normally the bend itself is about that without material but these have a lot of material either side of bend which is good to cut and play with. Puting i thtis way sounds a lot better, for a 180sx with an SR20, i you could get a cull cat back exahaust in 3" made for about 100 bucks (without muffler)... it will cost more for the flanges to bolt up to the cat than the bend needed and piping to make the rest as they only really need one 60 odd degree bend in a good straight system. So let me know and i can fill you in on whats lieing round at the time so feel free to PM me.
This is not a profit thing, i am basically just trying tos top it all being wasted cos we get about 20% back of the material value when its recylcled which is a real waste, so if we can cover the material cost it will save us and the environment, cos it can't be totally recylced!!
https://www.sau.com.au/forums/topic/25955-cheap-mandrel-bends/
Um it's in knox, but i can bring the bends home easily. Guessing from when i did mine it will be 60mm piping on the turbo side to the cooler then will go up to bout 3" to the plenum from the cooler but not 100% sure. But let me know and ic an tell u if i got the bends.
All alloy is 3mm wall thickness and is 6003 T4 bending grade alloy (very exspensive shyte). Steel is 2mm mild steel, have some 3mm in 60mm piping but only two and too heavy to use i reckon. As for making up cooler piping i couldn't physically do it without the car being there to custom fit it cos then i would simply just be able to bend up a one piece pipe rather than have to cut and weld, is much neater and better flowing as there is no inside joins to interupt airflow.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
