Hey all,
As i work with a mandrel bender on a daily basis, i was talking to my boss the last day or two and was chatting about all our left over bends that we have lieing round and we thought bout just getting rid of them cheap to guys interested in them for like cooelr piping and exhaustt systems. Generally i get a lot of 3" alloy and steel, both perfect for cooler piping and definately steel for exhausts, of which i had my dump pipe made for about 30 bucks. We bend from 40mm tubing up to 4", but generally the most used is 3", 60mm and 50mm. 60mm alloy is perfect for R33/32 intercooler piping which is what i used on my car, 50mm for some like 180sx's coming off the turbo etc and 3" is good for the outlet side of the cooler going to throtttle body on say SR20's and so on or really good for GTR's and gtst's running larger turbos and what have you. I try and put aside as much of them as i can not to waste them, and at themoment i have about 15 odd 3" mandrel bends ranging from about 45, 60, 70, 75, 90 degree bends in steel, in alloy there is a handful or 3mm wall 3" 90 degree bends and a few in 4.75mm heavy gauge piping in 90's aswell. There's a couple of 60mm 90's and a heaps of 50's. On a weekly basis we usually have this many lieing round constantly rotating between sizeing depending on what i am bending at the time for different jobs. So if anyone is interested PM me if you have any size of what you need, i think he was saying about 15-20 bucks each or something which is damn cheap cos normally the bend itself is about that without material but these have a lot of material either side of bend which is good to cut and play with. Puting i thtis way sounds a lot better, for a 180sx with an SR20, i you could get a cull cat back exahaust in 3" made for about 100 bucks (without muffler)... it will cost more for the flanges to bolt up to the cat than the bend needed and piping to make the rest as they only really need one 60 odd degree bend in a good straight system. So let me know and i can fill you in on whats lieing round at the time so feel free to PM me.
This is not a profit thing, i am basically just trying tos top it all being wasted cos we get about 20% back of the material value when its recylcled which is a real waste, so if we can cover the material cost it will save us and the environment, cos it can't be totally recylced!!
https://www.sau.com.au/forums/topic/25955-cheap-mandrel-bends/
Um it's in knox, but i can bring the bends home easily. Guessing from when i did mine it will be 60mm piping on the turbo side to the cooler then will go up to bout 3" to the plenum from the cooler but not 100% sure. But let me know and ic an tell u if i got the bends.
All alloy is 3mm wall thickness and is 6003 T4 bending grade alloy (very exspensive shyte). Steel is 2mm mild steel, have some 3mm in 60mm piping but only two and too heavy to use i reckon. As for making up cooler piping i couldn't physically do it without the car being there to custom fit it cos then i would simply just be able to bend up a one piece pipe rather than have to cut and weld, is much neater and better flowing as there is no inside joins to interupt airflow.
    • Thanks for your insight, it being basically useless will impact my decision for sure. I thought it may help the engine breath better I guess. But then again, I have also been told that tuning an RB20DE is also not worth it. Exactly, we follow EU Regulations. There is a bit more leeway on older vehicles. My Porsche 924 came without a cat from factory and managed to pass, they still mentioned that I have quite high emissions on it though.
    • My apologies, I stand corrected. Thanks for registering to mention this! And thank you for actually reaching out to the council to clarify. This is the sensible thing to do and the opposite of what I was alluding you were doing. I may have seen too much outrage and hate being fueled on the internet and it has made me a somewhat cynical old man. Sometimes it is easy to forget that there are real people behind websites and accounts. In my defence, CarExpert and CarExplore do read quite similarly at a glance. I shall try and do better in the future. (Please stick around to get the latest scoops on dealing with old Nissan shitboxes )
    • Don't bother. The poor little RB20 doesn't make enough gas flow to challenge the flow capabilities of even the littlest cat, and you won't make any extra power, and all you'll do it soot up your rear bumper. Plus....is Malta not runing under Euro regs?
    • Hey Daniel, sorry to hear that and thanks for posting up for us at a really hard time I only knew SmoothLine through the forums, we never met as we are based in different states, but when he was most active on here he was quite a while back so not many of the current crowd might remember him. I am pretty sure he was active in the Queensland SQU club but that is defunct now too (times are changing and we are all getting older). Farewell SmoothLine!
    • Turns out depending on whether the car was equipped with TCS or not there are different signals coming to the dash, meaning there are different speedo clusters.  Wired in a speedo calibrator box from aliexpress and now works fine.
