the coin needed to get the RB20 head to slow that of a RB25 (is you stroke to 2.4) doesn't justify the cost IMO.
But ye, 26/20... lol
Do any of the mods we do justify the cost?
Not really.
If you wanna build a tough 20, then you're going to build one. And you wouldn't bother putting a 26 head on top...way too much work reducing the combustion chambers. The only downside to a 20 in the cylinder head department is the valve sizes. Fix that and put decent cams in and away you go. 20's are stronger, rev higher more safely etc, etc.
It's like the CA18, everyone says they are a piece of shit 'go for the SR', but they are wrong. A fresh CA will outdo a fresh SR with similar dollars spent
Here was me initially thinking this was a topical pisstake thread relating to the RB26 vs 30 one hahaha.
Seeing as there was a question asked about trying to make an RB20 breathe I may as well try an answer - doesn't one of the R34 offerings have a Neo RB20 head? Are they any better than the R32 one? Maybe that could be something worth looking at?
Heres a picture of the intake port job we did on my rb20head to flow for the rb24 build
I can't get one of the exhaust because the manifold is urrently attached too it.
so why did you open up the port entry to slow down the air? did you touch anywhere near the valve seat?
Of course... rite down to the valve seat. intake is port matched also.. no problems with air speed at 30psi :banana:
Toque x Revs = horsepower.
So, RB20 doesn't have mcuh torque, so rev the poor little thing as hard as you dare!
In order to rev really stinking hard, it will really want to breathe..
This thread doesn't seem that silly when you boil it down. Sure, there may be a better way of getting the airflow your after, but I cant see the issue with starting with a head that already is known for lots of air and has a massive amount of parts you can buy off the shelf to help you.
Issues doing any kind of build will always bugg you,
but i bet everybodies jaw would hit the floor if they got past by an RB20 revvvvving @11 000rpm.. or higher! The sound would be like an R1 on roids.
Say good bye to any spare time and all your cash! but you sure have proved one thing, nobody is going to beat you to it!
I say Go for it..
How are you going to address the fact that the bore sizes are seriously huge mismatches? 78mm bore into a chamber designed for something with a 86mm bore? Its not going to be nice in there at all.
+20
It's not a stupid idea but it's stupid if you try it. People are always trying to re-invent the wheel. You don't need a 26 head on a 20 block to make power. Just because it's a 26 head doesn't mean you are automatically going to be able to rev it to 11k and make 1000hp. Thats a crock of shit. And as far as revving an engine to 11k, It's not just the cylinder head that limits rpm. Crankshaft, rod length, stroke etc all play a role. With a cast crank you are not going to safely rev a 20 past 9500rpm.
It's like putting a 20 head onto a 30 block. Stupid. Increasing compression ratio in a forced inducted engine is as simple as increasing boost. Plus chamber sizes are far too different to make it work. Going that way is more practical than 26 head on 20 block though. The valves will hit the edges of the block on the way down and you won't get the head gasket to seal.
But if you have unlimited funds and want to make something that no one else has, then go for it. You will have an engine that people will say 'wow, that's impressive' but then will wonder why their mum's corolla can nearly keep up with it.
TUF120
http://www.boostcruising.com/forums/index....=317565&hl=
AFAIK was running a 26 head on his 20...
He is on this site but cant remember his user id?
edit here he is! http://www.skylinesaustralia.com/forums/RB120WHY-m24062.html
Edited by dano4127
I have a 26 bottom end and head. What would b easiest is that i throw the RB20 crank in the 26 block with 26 head. Running the 86mm bore will give me a bit more diplacement but also increased weight of the pistons. But the shorter throw crank would make the thing a crazy rev happy engine. Dont understand why you would do it though, other then for shits and giggles or a class of motorsport that dictates your cc
    • The jack pad placement always had me scratching my head. I only have a small section to work with on both the E90 and E70 (and insert new project car here ) and I could see lining it up to be a bit of a bugger. For me, the E90 is just too low and needs small ramps and then the front centre jack point is a bit tricky to line up (it's half way down the subframe and about the size of a tennis ball, its really hard to see unless your head is on the ground), so I definitely like the idea of not having to do a multi-stage jack and just sliding these bad boys in under the sides. There's only one small point at each corner, so I can't jack AND add a stand on the same corner. Or, maybe I can and I'm too nervous to try. 😟
    • Is this not the biggest deal of all? I was hoping the whole "will slide under cars with skirts etc and lift evenly quickly with minimal fuss" was the entire point of such a device?
    • Here's Neil's car up on mine recently
    • Yeah I've got one of these, Quick Jack not Quick Lift, but your link looks like a good copy For me, it's better than no hoist, but it is definitely not as good as a hoist  It lifts the car about 60cm which is a nice working height compared to regular stands and it is only under the sills so it doesn't get in the way like regular chassis stands do.  No need to use regular stands, it has a safety lock on it. On the down side it is really heavy/unwieldy to drag into place, and you have to place it after the car is there (no option to drive the car to where the frames are. You need to try and line it up with the proper sill points which is hard as it swings up in an arc and there is surprisingly little adjustment in the distance between the rubber pads for different car lengths. Not a big deal, but in practice a jack + stands is probably quicker. Also there are hydraulic lines to each side and you need either a 240v or 12v source to power it depending on which option you have, I use 12v as I always seem to have a battery around.
    • Finally addressing my catch can and oil setup Plan is to do as much as practical without having to remove the motor or pull it apart. (no back of head to sump drain/breather or oil restrictors) First step is a set of full length baffle plates from Hypertune and a Tomei cam cap stud kit. I could probably have laser cut and bent up my own ones but this took any guess work out
