Fs/eoi: Pair Of 17x8 +32 Silver Work Meisters 1 Piece + Bridgestone Tyres $500
hey guys up for sale are a pair of work meisters in silver. they are in pretty good condition although the paint on one of the rims is starting to flake and one has a tad bit of gutter rash but otherwise still in pretty good condition. the stickers are there but kinda fading away. dish shines up pretty good as you can see in the picture.
tyres are bridgestone potenza re050a with about 50% tread with abit of camber wear.
was fitted on the front of my 32 gtst and fills up the guard pretty good.
selling these as a pair only because looking to upgrade to 9".
pick up in western suburbs only.
$500firm
hmmm.....i don't know for sure but i highly doubt it as they just clear the 4 pots with about less then a cm to spare on the 32.
if ur really interested come down and we'll try one on.
EDIT: just saw where ur from lolz. maybe some one can tell me if they do?
Edited by jakez88
got a quote from pack send that from vic to qld should be around $120. happy to send them now as there is a pack send branch near my uni and can drop them off after skool. adelaide/nsw/act/tas should be much cheaper obviously.
bump bump bump bump it up.
i'm pretty firm on $500 guys. everyone knows how much these are a set so $500 for a pair i think is pretty cheap already. msg or call me on 0432454387 for a faster response.
Edited by jakez88
  • 1 month later...
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
