but what if the skyline had, like, sic cat back zorst and some HGE boost. Wouldn't it win then?
I heard the F1 cars don't have much torque, so maybe if they raced on the uphill :confused:
Originally posted by Silver-Arrowz
the ferrari wins cause it's got more stickers. More stickers = more HP.
Yeah, you're right about that, you should see how many stickers are going on for Dutton rally.....we are sure to kick everyone's arse
Originally posted by Rezz
This thread should be titled "Ferrari F1 car opens up a can 'o whoop ass on pit crew member"...:P
:bahaha: yeah, I would have except there wouldn't be a "vs" in the title :)
Do you reckon that crew member made a mistake at the last pitstop and it was payback time?
bit of insite into f1
An F1 car is made up of 80,000 components, if it were assembled 99.9% correctly, it would still start the race with 80 things wrong!
Formula 1 cars have over a kilometre of cable, linked to about 100 sensors and actuators which monitor and control many parts of the car.
An F1 car can go from 0 to 160 kph and back to 0 in 4 seconds.
At 550kg a F1 car is less than half the weight of a Mini.
In an F1 engine revving at 18000 rpm, the piston will travel up and down 300 times a second.
Maximum piston acceleration is approximately 7000G (humans pass out at 7-8G).
Drivers haven't had to resort to pressure suits like fighter pilots because they only experience high G's for very short periods of time.
If a connecting rod let go of its piston at maximum engine speed, the piston would have enough energy to travel vertically over 100 m.
If a water hose were to blow off, the complete cooling system would empty in just over a second.
Gear cogs or ratios are used only for one race, and are replaced regularly to prevent failure, as they are subjected to very high degrees of stress.
The fit in the ****pit is so tight that the steering wheel must be removed for the driver to get in or out of the car. A small latch behind the wheel releases it from the column. Levers or paddles for changing gear are located on the back of the wheel. So no gearstick! The clutch levers are also on the steering wheel, located below the gear paddles.
To give you an idea of just how important aerodynamic design and added downforce can be, small planes can take off at slower speeds than race cars travel on the track.
Without aerodynamic downforce, high-performance racing cars have sufficient power to produce wheel spin and loss of control at 160 kph. They usually race at over 300 kph.
The amount of aerodynamic downforce produced by the front and rear wings and the car underbody is amazing. Once the car is travelling over 160 kph, an F1 car can generate enough downforce to equal it's own weight. That means it could actually hold itself to the ceiling of a tunnel and drive upside down! In a street course race, the downforce provides enough suction to lift manhole covers. Before the race all of the manhole covers on the streets have to be welded down to prevent this from happening!
If you've ever changed a tyre, you know that you have to jack the car up off the ground to be able to replace the wheel. And it takes ages. F1 cars have integrated pneumatic jacks in the chassis (rather than the manual jacks normal cars have) - two in the front and one in the rear. By connecting a pressurised nitrogen hose to a port located behind the driver, the pit crew can jack the whole car up in less than a second when the car stops in the pit.
The refuelers used in F1 can supply 12 litres of fuel per second. This means it would take just 4 seconds to fill the tank of an average 50 litre family car.
Top F1 pit crews can refuel and change tyres in around 3 seconds.
Race car tyres don't have air in them like normal car tyres. Most racing tyres have nitrogen in the tyres because nitrogen has a more consistent pressure compared to normal air. Air typically contains varying amounts of water vapour in it, which affects its expansion and contraction as a function of temperature, making the tyre pressure unpredictable.
During the race the tyres lose weight! Each tyre loses about 0.5 kg in weight due to wear.
At ~ 350 mm wide, F1 tyres are much wider than normal tyres (~185 mm wide).
Normal tyres last 60 000 - 100 000 km. Racing tyres are designed to last 90 - 120 km.
A dry-weather F1 tyre reaches peak operating performance (best grip) when tread temperature is between 90°C and 120°C. At top speed, F1 tyres rotate 50 times a second, or 3000 rpm
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
