Petrol tanks are way more likely to explode or burst into flames in an accident. Also leaking petrol goes off just the same as leaking LPG. Anyone checked the figures on it?
Lpg is excellent if installed and setup properly. Had 5 gas vehicles over the past 20 yrs. Saved about 40% or more on fuel.
Only problem was on a vl - exploding airbox. Fixed with a pod filter.........
Airboxes explode because residual Gas sinks down the intake tube into the airbox (lpg is heavier than air) Especially after backing off from a hard acceleration, as throttle is opened again.
If the conditions are right kaboom. Scratch one airbox ,and or airflow meter. Pod filter lets the gas out enough to prevent this. $20 fix
Got the old mixer gas setup on my VT Commodore daily, runs perfectly (had it on there for the last 20,000 kms) It gets 550-600kms for every 72L fill of gas ( half city/ half freeway driving)
The car has never back fired once, the workshop that installed it said that he hasnt any of his cars blow up an air box in years, something to do with drawing vacuum from the other side of the mixer or something. Whatever they do it seems to work :blink:
I love gas. Had a carby and injected commodore V8 and both were great. Always a bit of comprimise with idle speed etc but saved me so much money. I love watching litres go up faster than dollars at the pump haha.
Yeah but pretty sure spontaneous combustion is more likely in an LPG car. There are way more petrol than LPG cars on the road, and I haven't heard of spontaneous combustion (unrelated to accidents) of a petrol car recently, but I am open to suggestion.
    • Following from this in a related by not closely-related sense... Because I was buying a bunch of other GKTech stuff, I got some rear subframe collars. The history that leads up to this is: 25+ years ago the car arrived into the country with stock subframe bushes. At some point shortly thereafter I added Whiteline pineapple rings, set up neutral, and it improved the rear end behaviour. Well, it is my vague memory that I was happier with it with them in. Less axle tramp on launches, generally better, etc etc. ~2012 it got a new non-HICAS subframe with new stock bushes. No pineapple rings. I reckon that ever since then I've been dissatisfied with the axle tramp. Recently I've been f**king around a lot with all aspects of the suspension. One contemplation has been to relocate the rear lower control arm front mount points (and do the other things needed to make that work) to improve longitudinal rear grip by getting rid of some of the stupid anti-squat that Nissan ladled into the R32. But.... before doing that I thought I'd put some collars in. And.... The collars are good. The rear sounds a little bit different, but there has been no significant increase in NVH coming up into the body. In terms of rear behaviour - expansion joints on long sweeping elevated freeway ramps that would sometimes cause the rear to jiggle around a bit, no longer seem to do so. It appears that jamming chunks of metal into the gaps in the rubber so they can't move much is a really good thing. And the launch behaviour and general forward traction situation seems to be greatly improved too. It's impossible to be really sure, because the tyres are completely shagged - they are freakishly willing to let go right now. But as an A-B test with the same tyres it certainly seems to grip up a lot better. Highly recommended to anyone who still has stock bushes.
    • Bit off topic maybe but has anyone had a crack at one of those aftermarket electric compressors ? Bit of a search came up with one put out by Speedy Air Spares. Looks interesting and looks as if you'd have to run a big arse alternator. Found this out after the fact as my air con compressor packed it in and soon after my alternator ! !
    • Yes. Needs new ports. Usually just achieved by screwing an adapter onto them. Be aware that any AC compressor that hasn't been used in a long time will very likely have dried out seals and will not hold gas. Oh, and obviously you will require a new receiver-dryer also.
    • Can you covert an R32's AC from r12 to r134 if the compressor/hoses etc are still all good? Pretty sure on my car the AC was degassed when it was imported  to remove the naughty r12 and save the ozone layer, and the fancy climate control system just blew air around. Was happy to drive the car with windows down back then, but now I am old and need to be kept cool
    • Just to circle back here, I've sold my automatic trans to another Stagea owner in OH.
