Hey ppl, iv tried searching on here for a while but no luck, hence me making a thread up.
I need to know whether the z32 fuel pump is able to be fitted in the R33 GTS-25t.
I understand they can outflow the walbro's, and aparently on the z32 tt, good for over 500whp.
Could someone please shed some light on this?
Thanks.
https://www.sau.com.au/forums/topic/259631-z32-tt-fuel-pump-on-r33/
Thanks.
I know that the OEM pump flows 260lph at 45psi so they are comparable to a Walbro.
Because of the design of the pump, it would be a tricky install as the R33 gtst is slightly different. They look more like the pump used in an R33 GTR.
Not completely impossible for a competent person.
My best advice is to pull the pump from your 33, and look at the two side by side and make your own determination.
To pull the pump should only take about 30-45 minutes.
Good luck man and keep us posted.
45psi - Dam, i thought it was around 50-60psi. means i cant run much boost at all with the z32 then.
The wallbro pushes around 60psi or so, therefore with the base fp or around 40-42psi, means it will run out of fuel if i boost past 15psi roughly.
Has anyone attempted to fit the Z32 in their R32/33/34?
http://www.skylinesaustralia.com/forums/Fu...mps-t20800.html
From second post "an R32/33 GTR or Z32 TT fuel pump, fits straight in and good for 260 rwkw"
once you pull the pump cradle out you'll see what your up against :banana:
try looking through this topic - http://www.skylinesaustralia.com/forums/Bo...tr-t111401.html
    • I’m guess it’ll end up with a turbo
    • To install new hicas ball joints do i really need to pay for the Frenchys hicas install tool? Or can i use something like this? https://www.ebay.co.uk/itm/395524214497?_trkparms=amclksrc%3DITM%26aid%3D1110018%26algo%3DHOMESPLICE.COMPLISTINGS%26ao%3D1%26asc%3D281023%2C280568%2C280618%26meid%3D4018390c9ba246f794ed58b8b19ec80a%26pid%3D101430%26rk%3D4%26rkt%3D12%26sd%3D205160403603%26itm%3D395524214497%26pmt%3D1%26noa%3D0%26pg%3D2332490%26algv%3DCompVIDesktopATF2V2AndXaiHotClickWithCompV6WithEbertNRTRecall%26brand%3DUnbranded&_trksid=p2332490.c101430.m2460&itmprp=cksum%3A3955242144974018390c9ba246f794ed58b8b19ec80a|enc%3AAQAKAAABMDJfxvEKz%2FWsdyy97PIVwAhtkTIJPGKp%2Bu7TYjjsvNO4eN9duTRR%2FSVFYts6UXmN8tSK75ee0LypjLaKkPNQ2gkat4DyNLnViXKBVpI1%2B5fAYfWiGJa5QlqEPseqbSJUD9gVo2KSXbnmQjuPDJH4flTH2bOLSO%2FvMrLjgPDIc7vGrlKtoSauZb0q%2Fu43zLR0J8tg1z5dPMV%2FcHtnqRYXb7R7V8G%2FrQGhpY1sWtGJXc4TWc78ccs69UXnMiCqqd05ITd%2BY7Vwbq5Uzd%2FWhmiZCytO66vqDnbJn03qN%2Bin0ImF5sgbgu9uD45tXNN8cr4IWfqzIEEpaKcgqilwbTDxMkIQ4sGcgz7IhYONV017vE6P9ksZ7n%2FFVwgs3kAfMb0%2FLGjwaqhwo0yilTIjGHg9mwU%3D|ampid%3APL_CLK|clp%3A2332490&itmmeta=01JMR0X9WMB8DPEX82P2P3CRXN
    • I would be lying if I said I wasn't interested in what MCM were going to do with the NC I really enjoy their banter and occasional collaborations (like Alan from TSF, Ben from BCW, or any of the Haltech guys throwing around their experience), and I have probably watched everything they have put out
    • Not yet, we basically drove it to a private road, got the logs and drove it straight back. I think I need a new passenger seat belt after the mrs squeezed the life out of it.
    • Sounds insane! 🤤🤤🤤  Do you have any vids of it driving?  A flyby would be nice!
