No Paul they didn't do it this year mate. Last year it was too easy to "clean" the stage, and it was too hard to find a way to slow the stage down. Shame, I loved it last year, very fast :dry:
Reverted back to the old Mt Black and Roseberry, and added in Rinadeena, which is Strahan in reverse! :D
Now, whats this about you driving the event, how did we miss you?
  • Replies 652
Posted Images
I wish - nah I meant in 2008. Timing was all wrong for this year but next is going to be a ripper.
Yeah shame - we had a ball that day, even though we had a small off. Steve managed to wrestle the fish tailing car down from about 180km/h, around a 9 corner, to gently dropping the front wheels into a ditch.
wow. I thought it was a typo and was meant to have a -R in there! yeah the sunnny GTI is AWD non-turbo. pretty average piece of gear. they must have been pushing it pretty hard to get that far up the order. well done. :sick:
Yeh he has been multiple National and State F2 Rally champ in years gone by.
Did they do Reeces dam again this year? Was there similar carnage on that last stage as there was in 2008?
Nahh went back to Mt Black and Rosebery, I reckon there would have been major carnage this year had they been run was wet as over the west coast.
Gee I was getting all confused there Paul! :sick:
Well, with luck, we'll see you back there next year too, gotta start searching out all that spare change that I know is hiding around here somewhere..... :(
wow. I thought it was a typo and was meant to have a -R in there! yeah the sunnny GTI is AWD non-turbo. pretty average piece of gear. they must have been pushing it pretty hard to get that far up the order. well done. :P
wrong on both counts haha Lee's GTI is front wheel drive, as are they all I believe. Its also certainly not an average bit of gear. It is an absolute animal and Lee is a driver of top top quality. Had a few problems I think on day 1 and dropped a lot of time. Can't wait to hopefully see it in the forests this year as it is a sight for the eyes and especially the ears.
the gayness that comes from your typing hurts baby jebus
homo!
I RECON I SHOULD ENTER ROOKIE AND TEACH YOU ALL HOW TO WRAP A CAR AROUND A TREE!!
alright who let Pete into this thread :D
reckon you should do it Pete (the rookie bit, not the wrap the car round the tree bit)
though you would need to find some SERIOUSLY insane to navigate for you.
jenna has indicated that she wants in( lol)
if i can find a gtsT with a rol cage ill be there next year
other oprtion is to put a cage in jennas car :)
Well you're in luk my good man, just so happens I have a caged 32 right here for you..... PM me for details and price :D
!!!!!!!!!!!!!!!!!!!!!!!!! Sammy had some input into that story huh!?!?
http://3.bp.blogspot.com/_tB-f-t-7QXw/SgrB...SMANIA+copy.jpg
Hooo-hhooooo-harrrr! lolz
do you think rod will ever live that crash down? esp with the responce it got on the party tape
maybe Thumper will.
on a side note, I only found out on the weekend that our car had had the front springs upped to 500 lb/in from 330, hence the front of the car contantly leaving the road....not happy
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
