Thanks Scott, Kel, :) I Timmy has balls of steel I reckon, a real pro ;)
I think a roof view or bumper view could better relay the actual pace of it.... probably the lower the better?
I need to sort out a camera now, as this POV was Dan's!
  • Replies 652
Posted Images
Thanks Scott, Kel, ;) I Timmy has balls of steel I reckon, a real pro :D
Oh the withdrawals!!!!
I was planning on buying a POV for the Rally season start next week, but meh too much other crap has come up recently...
Maybe if we get one each, multi angle :D
And apparently the POV is good for the bedroom too?
Now why on earth would anyone want to see multi angles of you and Wooster in the bedroom Timmay? :P
I think you are right Ben the lower the faster it seems. You check out this vid and it seems like the car is going 200mph (about 1:00 in)
Don't forget Targa is on the telly this weekend!
From Helen @ Octagon's email this morning...
Australia's top tarmac rally will be on show in lounge rooms around the country this weekend, with the Seven Network broadcasting a one-hour special on Targa Tasmania on Sunday at 12 noon. Locally in Tasmania, it will show on Southern Cross TV.
I'm guessing your driving skillz -particularly when it comes to field plowing - will feature prominently Benny :)
lol I guess they might, I can only hope they set the record straight and state that the only reason we ever left the road was due to bad and/or late navigator calls :)
Well if you want to be on TV it seems you need to be either in Showroom, Outright Classic or Modern.
I don't know why they bother with the other catagories really :P
Anyhoo - it got me thinking way ahead for a couple of years time of looking at Classic cars (since the budget for Modern is plain silly). I was under the impression that the upper date for classics moved but it seems it is now stuck at 1990. Is that the case (Stu?) and how long is 1990 likely to remain the upper limit for Classics? I was looking at some 1992 cars for the 2011 race but I take it they won't be available for Classics?
Na I'm thinking either an NSX or RX7 but which ones will depend on the data.
I really wanted to do an NSX Type R but thats a 1992 car. Having said that there was nothing majorly special about the Type R other than suspension and weight - which I can do both under the rules regardless.
I don't know why they bother with the other catagories really :banana:
You shouldn't necessarily change your car and category just so you can get on the dvd. Not everyone gets on the dvd as ben said and it even states in their policy you aren't gauranteed coverage http://www.targa.com.au/Competitors/Publicity.html
If all else fails you could drive through a fence? I wouldn't recommend it though!
Geeze talk about original... maybe we should go with something different benny? Delorean? atleast then we could go back in time and change history in the unlikely event we got beaten by these sheep!
Next thing you know Classic will be called the 32 GTSt Invitationals!
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
