nah it all went bad. probably oil pump failed bacause i lost all pressure suddenly but the big end bearing that has spun doesn't sound too bad. hopefully not too much work to fix it....last I heard the motor is already on the floor sounds like brad is pretty motivated so see what happened :down:
I on the other hand intend to celibrate this motor's life by getting shitfaced. It had a brilliant record, 4 wins from 5 starts. It's short life will always be a highlight for me.
Round 3 isn't until 30/may so 6 weeks to sort it....if its not too bad that should be do-able. Any chance of doing OK this season is gone though because I missed 32 points in the enduro this arvo.
  • Replies 156
Posted Images
Hope it's only as bad as Brad thinks it is mate.
Good luck. Don't let it knock you, you did awesome out there today, killed them all, some great driving!
yep his as serious as they come
Its all out and stripped in the garage.
Has wiped 5 and 6 big end bearings only the upper bearings are really damaged but its enough to have a slight knock.
Will have to pull the oil pump apart tommorrow and see whats going on there and perhaps build a better sump for it. First impressions are usually right and it looks to have surged.
The rest of the engine is mint as it should be.
Edited by Risking
On the bright side, the impact on points in the overall championship may not actually that bad (however that statement needs to be qualified by the fact that our calculations are already half pissed and by no means offical!).
We look to be sitting about 15 points off the championship lead (a race win is 16 points) so it could have been much worse.
And hopefully we can get the car together and back on as good for the next round.
No pressure Brad :down:
Actually MASSIVE thanks to Brad for his offer to strip it all down & fix stuff- we really appreciate it.
And as you can see he's already got stuck in - now that's commitment!
I got the text last night about the win again, was stoked to hear!
But after reading now, man thats gotta suck, sorry to hear :(
glad to hear Brad's on the job!
Hope its no big hassle and you guys will be there next round to get more winnnnnaaaar's points :down:
We'll be back well before the next round.
Its bad but not as bad as Duncan's previous attempts to break it.
At least everything is where it belongs and it still goes roundy round realativly smoothly
Big congats to holt and howard for taking out the enduro, would not have been an easy feat with 4 cars on the lead lap.
I also noticed that Jacksons Calibra finally cracked the 1 min 1 second around there with a 1.00.58!!!
That is some serious pace!!!
Edited by Risking
  • 4 weeks later...
oh you are a nasty piece of work. get off the interweb and back to the garage....I need to enter in the next 2 days so I need to know if it will be ready or season over :P
I've got the water lines back at least....let me know which night we are sealing it up. And you owe me bank details still....pm me.
Dave, are you back for the next round? Brad have you entered? anyone else popped up to have a go, I don't know if Mick has found the thread yet but he was in prod sports in an rx7 at EC with scott helping out
engines done buddy, everything is weighed withing a gram of its life, balanced to perfection and assembled.
Sam ended up drilling out the oil returns, the crank I told you about, few other little things to help with oil control. We line bored the main journals too be sure as well.
Iv'e got one piston back out sitting on the bench and eveything laid out for old mate Mike Hanley to come seal it up. Regardless of the cams being back or not im sealing it up wednesday night. Mike can come back with the cams once the engine is in for all I care. He can seal the sump and head then seal the covers latter.
Once the head is on I can do the turbo's and external oil pick up crap without the cams. It will be going in next saturday and you will have it back by tuesday ready to race.
Im very impressed with the oil pump, its a really nice unit. And wait till you see the sump in person. You bash it against a ripple strip and im coming after you!
Im not aloud to drive for a while (doctors orders) so I have not ended up entering this round. Jay is going to take it out to the SAU oran park day.
The car is back here now so you can suss it all out when you come down during the week. Its getting some suspension surgery over the next two weeks.
Edited by Risking
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
