haha, thats a pretty good way to put it. Saturday is way to late.
Didn't have a problem supplying oil to the head, its just where it was not going once it was in the head that was the problem...
Sam rekons shit from the previous engine has blocked the gallery to the front journal of the exhaust cam. The head was obviously cleaned but blocked cam gallerys are not really something thats usually a problem.
Luck it didn't get to far gone and the thing can be repaired.
Jay's wrapped cause he gets to pull it back out now. Im liking this whole being sick and not aloud to do anything thing at the moment. Watching you lot put it in the first time was funny let alone again.
Im going back to work tommorrow, im so tired of sitting around home!
There's only so many steven Segal movies I can handle...
Edited by Risking
  • Replies 156
Posted Images
there's a few competative sports sedans on my105 atm for well under 50K kel!!
Bad luck just seems inevitable with this thing. My GTR better not catch it while they are around each other thats for sure
Edited by Risking
well actually, if you wanted to see my car run.....waiting until sat was too late.
oil supply issue to the head led to a snapped cam while running it in - so I've gone from just making this round to missing it by a mile :D
Looks like the Dinosaurs are one put on you Mister D
Maybe try a 20 lt sump next time around LOL.
xxxx
Was definately some interesting racing out there on the weekend..Most did really well driving to the conditions too.
I was doing Race Control and sad that you weren't there Duncan would of had prime viewing of your awesome launches off the line!!
Hope you get her up and running soon! :)
Its still broke Chris.
The head is repairable but we're half way through building another new head for it. Don't know exactly where the problem is with the old one yet so not taking any chances.
New one just needs stem seals, valves and springs them clearances adjusted.
Looking like we may pull the bottom end back out and double check there is nothing in the main gallery that could have blocked the head supply even temporarily.
Once we got the head off the bottom end was cranked over to make certain it had good oil supply to the gallery. There was a massive mess as oil streamed out the restrictor. So far it seems there was something wrong either with the gallery to the front cam cap or the bucket bleeding off oil to the front gallery. Either way its really annoying as the head was litterally removed cleaned down and bolted back into place.
  • 4 weeks later...
hey there are still 4 weeks to next round, it will be back then for sure.
lol famous last words...
I've sort of been sooking since I missed this round as well. We did get that motor back together but a related problem saw the new one die pretty much straight away. At least we know the cause now :P
In any case, the motor is back together and sealed so my next race will be the day/night meet (last one??) at Oran Park 1 August. Next state round is not until mid September at Wakie.
There was a round on this weekend, and aren't the taxis going quick these days. Gus' new monaro did 1.46.5 in qualifying...bloody quick for a stock 2 door taxi. Jim ended up winning the round in his dinosaur. Best modern car was Gerry's evo 7 in 6th.
As for the other categories....the BSM GTR was not out again, and as usual the sports sedan field was rubbish, 9 finishers in the last race. improved prod is struggling for entrants too with only 24 finishers between 2 fields (over and under 2l). And very sadly the over 2l improved prod quickest car was slower than the production cars quickest. Its basically a crap time for quanitity and quality of entrants in racing.
Hey Dunk, is it true that the Commondoors don't have to run the class control tyre (Kumhoo) while everyone else does?
Cheers
Gary
lol I'm sure everyone follows the rules.
unfortunately the rules have been changed until the end of the year, no more control tyres.
all this means is that instead of everyone running on same kumhos (1300 a set to me) we all run the best tyre (dunlop dz03) at 2600 a set :blink:
After ALOT of screwing around and what ive now called Duncan luck he has just taken the car and its even driven 300odd Km's!!
We've now got a really nice sump which has a slight leak but fixable, a nitto oil pump and external pick up and a heap of other little oil mods which should keep the bearings going roundy round
Bring on the next engine failure Duncan im sure there will be something else interesting next time around.
We do also have a spare now though which is almost completed.
Day nighter in a fortnight and so far its looking like duncan WILL be there.
sweet let me know how it goes.
Im sure there is a few little things that will need to be tidied up underneath the car, like the box breathers and silly shit like that.
Bring on the day nighter!!
Oh and dont forget the oil filter!
Sam is anal about cutting it open to check after the first few changes.
Bring two spares to the track as well
Edited by Risking
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
