I'm about to book my car in at Formaz to up the boost a bit on my R34 (which is currently running the stock 0.55 bar). I've dealt with Kevin from Formaz for a minor service before and he seems alright.
Just a question: what's most boost I can safely and reliably run on a stock GT-t turbo/stock intercooler. Only mods so far engine-wise are cat-back exhaust and Apexi pod filter.
The numbers I've gathered from the forum are 10-12psi (0.7-0.8bar) without running the chance of blowing the turbo.
Kev said he has seen many Skylines running 1bar safely on a stock turbo/IC without any problems. Does this sound right? Keeping in mind I don't plan to do any trackwork or drag runs and that summer is coming up.
Also he plans to use a simple bleed valve + boost cut defender to boost it up. I've read here that they don't hold boost properly and cause spiking. I realise an EBC of some sort is the best option, but will this do? Must I have the boost-cut defender as well? Any comments?
Also, any general comments and experiences good (please share) or bad (PM me) with Formaz would be appreciated.
Cheers.
https://www.sau.com.au/forums/topic/25967-opinion-on-gt-t-boost-formaz/
1 bar is far too much to run on the stock turbo and cooler. The ceramic exhaust wheel will spin off and the car will probably detonate at that boost level with only the stock i/c. Play it safe keep it around 12psi tops, how are they planning on upping the boost? If its a bleed valve make sure you install a good boost gauge at the same time so you can make sure its not spiking too high. If you plan to use an electronic boost controller some of them, like the blitz dual sbc, act as a boost gauge as well.
the R34 have a plastic wheel which is just as weak as the ceramic one on the R33, it provides faster spoolup but will die just as easily keep at 12psi if u want it to be reliable.
that said i've seen plenty of cars run 14psi all day everyday on the stock turbo and coola with no problems.
ARGH34, just a thought , when u get the boost set , check to see that more boost = more power. Recently had mine tuned (boost spikes to 13.3psi then settles to 12psi) & discovered when we screwed more boost into it that the power dropped off! (Maybe knock sensor picked up some pinging & took out timing to compensate?) .Having said that , I would have happily run 1 Bar (14.7psi) if it went harder :(
I wouldn't bother running anymore than 10psi. The stock cooler in the R34 is better, but still will have 2-3psi pressure drop, but increasing boost any further will add excessive fuel, and you'll find power going down due to overfuelling.
The R34 GT-t's internals are better, the compressor wheel is nylon(plastic) but the exhaust wheel is still ceramic, and won't cope with over-boosting too well.
I'm sure even with 10psi you'll make good power.
Yep points noted. Thanks for the tips.
He said he'll take it for a whirl on the dyno when he boosts it up. I guess if nominal power gains are made with 12psi over 10psi, I'll just set it to 10. I suppose next time I wanna boost it I'll need an FMIC and AFC to make it worthwhile?
I was also thinking of getting a full exhaust done at the same time. What kind of a down pipe / front pipe should I be looking for? Branded or get one fabricated? How much are we looking at?
I noticed rob77 said $300-$350 for the pipes in the 'best mods for $5000' thread. This what I should be expecting?
Oh and any comments on Formaz?
I'd get the full exhaust done first. You may be surprised, but more than likely by doing the exhaust the boost may well increase to about 10psi by itself:D
Yeah, if your planning further mods then an SAFC and FMIC are on the cards:D
I'll PM you my thoughts on Formaz.
    • Definitely didn't put a N/A cluster in instead? The speed sensor (location) is different in both cars.... I think. This will obviously stuff things up.
    • Nah not the throwout bearing, it's something internal. I already replaced the throwout bearing. Mechanic misdiagnosed my car and thought it was a spigot bearing, went to another bloke who said it was an input shaft bearing. (I replaced everything when I pulled out the gearbox but didn't open up the gearbox.   In this video at timestamp 6:05 : Mine has the same sound  min
    • It is definitely to space it out and away for clearance during compression, and possibly for spring clearance to upper arm. That latter would only be true for springs that are same-ish diameter to stockers, and so that probably doesn't apply to Teins or most other coilovers.
    • Yeah, a mechanic who knows these cars told me even if I get a brand new gearbox the noise will return but will be less noticeable. I've heard someone also they this noise came back after 3,000km on a new or reconditioned gearbox. It is pretty f**king annoying though just hearing groaning most of the time lol. I wonder if an aftermarket input shaft bearing would fix the problem or how they are built.
    • All RB gearbags, especially the big turbo box, have rollover noise. Mine certainly does. Always has. Sometimes is worse than others - no particular idea why, although it is probably temperature related. I have smurf jizz in mine and have had to have it in there from the first day the box went into teh car. It simply would not select gears with the engine on, on day one, with normal oil in there. And so, the blue stuff has probably ruined almost everything synchro related in the box. But it has taken 12 or 13 years to get to the point where I simply must replace the box. It has become increasingly baulky of late, which might be symptomatic of the way I've been driving it, as much as anything. I shall have to make some corrections when teh new box goes in. Input shaft bearing noise will decrease with clutch pedal pressed because the drive is removed. But yes, more often than not noises that work like that are associated with the throwout. It won't matter either way, new box will mean this one can be relegated to the parts pile.
