  • Replies 159
that didnt happen last time...or is there something you are hiding??? :P;)
haha....is that where we were last time???? Didnt realise.
That place was rubbish :cool: rubbish enough to not even have a chance of contracting a serious or at least very worrying condition. Even the bogan single mums werent keen, haha
Stayin Syd tonight so ill see you lads at wherever that meeting spot is. Choice
You know where the spot is Ian?
Look out for a blue silvia and red mx5, that'll be Ando and me.
So 7:15 just after the bridge, which is just after the 2nd campbelltown exit!
Dont really know it but im sure shouldn be too hard to find. Ill be in my black beast and travellin with mate in stock liberty B4 (colour?)
PM me ur mob number if u get a chance tonight
don't know, mdtc have days all the time but nor at this price!
Well the lil red nugget has been doing almost flat 47s! Ando in 44s and Anthony - too much boost is at a 42!!
fark me!!!
what an epic track!!!!!
the lil 1.8l non turbo held its own and did great, still couldnt muster up that blue silvia, that thing is uber quick!
And great to come home to a cold beer!
Yes epic day had by all... think i ended up 2nd fastest behind Anthony (too_much_boost).. but man that little track is awesome!! Very technical and unforgiving, as a few cars unfortunately found out today.
The failvia did its owner proud but i certainly glad the MX5 doesn't have more killerwasps otherwise it all over red rover...
I got a passenger session with CHubbeh and i tell you what... I was giggling like a 5 year old girl... the thing is awesome through corners and sounds so so angry... its no hairdresser car!!
Chubbeh did bloody well to steer that thing round for a 46.9 and Georgie a 50.1 for first time out in MX5 and first serious track session was uber quick!!!
But i think Anthony n I did the S13/SR20 contingent proud!! Stoked with my 43.7.... next time i will go quicker LOL
Epic tired now... that feck its a short week and a 5 day weekend coming up!!
Yeah man you s13 drivers did awesome!!
restepa!!!!!!!!
Cant wait to head back there - but I need full wexhaust system now, stock exhaust = no powah!! :blink:
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
