no idea on the msd injectors but i came across this link this arvo on here... i was in the same boat as yourself by the sounds of it, not sure what injectors will suit a rb25 neo... the bloke i talked to, jason was too happy to help me. he knew exactly what injectors i was after and he understood some of the pain i have gone through to find a matching set... the injectors he offered me were siemens ones part # PF60HG he said to specify that they were for the neo engine... 630cc @ $180 each he also said they flow test each injector and provide i think a 6 month warranty but dont hold me to that could be more could be less all i remember is he said warranty :P
http://www.powerflowinjection.com/
https://www.sau.com.au/forums/topic/259719-msd-injectors/#findComment-4460958
http://performanceparts.com/performance_pa...es/msd_2014.jpg
So here it is... any idea by looking @ it if it will fit directly in an r34 Neo GTT?
MSD's competition fuel injectors are engineered to racing specifications and manufactured to handle the demands of high performance racing applications. They feature a MULTEC metering design to control the flow of fuel correctly and reliably every time and a six hole injector metering orifice that produces a totally atomized and compact 10 to 15 degree spray pattern. The fuel flow rates are set and calibrated at the factory to ensure that you get precise fuel flow. These injectors are compatible with alcohol based fuels and will withstand long term alcohol use.72 lbs/hr, 4/1A peak and hold, 2 ohms resistance.MSD 2014 Injector 72 lb/hr 2 ohm (4/1A) Competition Not legal for sale or use on pollution controlled motor vehicles.
Need to know whether the MSD 2014 injectors (top feed) are a 'direct fit' into the R34 Neo GTT engine.
Is anything else needed?
Cheers for quick responses
https://www.sau.com.au/forums/topic/259719-msd-injectors/#findComment-4462046
any ideas anyone?
will they fit?
https://www.sau.com.au/forums/topic/259719-msd-injectors/#findComment-4467293
not shure about neos.. but normal rb25's use sidefeed injectors... maybe neos are differnt from standard 25... someone will know?
EDIT: after more research i see neos do use topfeed..i think most topfeed injectors are compatible
Edited by ih4xjesus
https://www.sau.com.au/forums/topic/259719-msd-injectors/#findComment-4467348
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
    • yeaaa that's why I haven't done any wiring to the stock ecu harness because I have the haltech, but then that leads me to the other question of "is the pnp harness really plug and play?" or would I have to still switch some pins/wires over because the pnp is for the rb25det neo harness, and not for the rb20de neo harness. was really hoping to find something to spoon feed me since so many people have done rb20neo + t conversions, but man this is rough.
    • Temu raptor, lol. At least the owner isn't your typical ranger danger lot
