FOR SALE: Trust T88-34D turbo kit for SR20DET
ITEM CONDITION: Perfect working order, low kilometres and next to NO shaft play
PRICE: $4,000
CONTACT: PM
DELIVERY & CONDITIONS: Will ship at buyers expense
As the topic reads I'm selling this monstrous kit as I no longer have a use for it.
Since I didn't want to raise the bonnet the front housing has been milled to suit. The engine sat higher with Nismo mounts (S13)
It is in perfect working order and has not travelled many kilometres, the turbo has the same amount of shaft play as they do out of the Trust Factory.
The kit includes:
1 x Trust T88-34D with 22cm V-band rear housing rated to 850ps
1 x Trust 321 grade stainless steel manifold to suit SR20DET (very light)
1 x Trust Type C wastegate with 1.4 bar (21psi) spring and screamer pipe
1 x Front 90 degree Greddy intercooler pipe bend
1 x V-Band dump pipe (needs minor repair around EGT sensor bolt)
With Forged pistons, Poncams and the obvious external mods such as ECU, Injectors, cooler this setup made 315kW at the wheels on 21psi, > Sleeved block suggested for 360kW on 26psi and 387kW at 29psi on a race tune (good for low 10's at almost 140mph with a good launch)
Full boost at 6000rpm on pump fuel, 5700rpm on the race tune. Cam setup and better compression will see it come on boost before this and the ability to make way more power than I did.
Facts: * Despite the lag it does not fall off boost between gears
* I've had this around the circuit and it's perfect once you learn how to drive it by taking everything a gear back
* It will make your friends wonder if there's something wrong with their cars when it comes on and you sailed past them like they hit the brakes :)
* T88-34D is used by Australia's most powerful SR20's Benny Kashima's pink 180SX and the JUN S15 from WA
From the ex Hpi project car PJ321.
Replacement value over $8,000 see below
http://www.takakaira.co.jp/Main.aspx
http://www.tintmastermackay.com.au/turboch..._pricelist.html
Hear it in action:
http://www.youtube.com/watch?v=kmiRWQMLwF8...feature=channel
PM or call 0438 1600 81 if you're keen
PJ
https://www.sau.com.au/forums/topic/259737-trust-t88-34d-kit-for-sr20det/
OWNED this car with this setup insane power and nowhere near as laggy as youd think... much respect
fark i miss it.... its a damn shame u removed it PJ ... i knew it would be less laggy and more fun with something smaller but then it wouldnt have been a "T88 silvia" so i just couldnt bring myself to do it... i miss it baaaaad.....
Edited by WHITE R32
It's not too late John!! :P Buy another Silvia :laugh:
Yes I must admit everyone falls over when they see a T88 on an SR and the sound is incredible. I miss that big hit too to be honest!
  • 2 months later...
