I am selling Skyline GTS25T R33, which needs repairing. Had an accident and front right hand side been damaged. Have a look at the car descriptions and photos of part and orginal. If you are interested, please email me on [email protected] with your best offer price. Living in Sydney and pick up only. Spend much money on modification. If you want to have a look at it, please mention them on the email, then I will be able to show you.
This car is directly imported from Japan, and had it for about 3 years.
Thank you.
18 inch chrome wheels
Refurbished engine
exceedy sports clutch (6 months old)
hybrid intercooler
full performance exhaust system and 3inch cannon
boost controller
Performance air filter (Pump back system)
Sunroof
Spitfire tacho
Tinted windows
Full body kit
Boss steering wheel and stepping wheel kit
clear head lights and indicators fusion
pioneer sound system and amplifier
175,000km
260kw
Rego expires in end of July
Edited by DAVID KIM
https://www.sau.com.au/forums/topic/259756-selling-gts25t-r33-1994-accident/
would you consider parting the car out? also is that 260rwkw?
I can't. I don't have any garage. It's at my mechanic. Yes it is 260rwkw. This vehicle is pretty a rear one. If you want to have a look, please let me know by email
wheres the dyno sheet to prove?
which dyno did you go to?
what turbo you running? because I cant see any big turbo in those engine pics...
do you have upgraded injectors/afm/fuel pump/fuel regulator/computer to make 260rwkw? if not your not running that much power.
you have mentioned an exhaust, intercooler, pod and boost controller...... maybe enough to make a little under 200rwkw... and you know, 260rw HP is equal to about ~190rw KW... which seems more likely.
tell us your mods, show us your dynos before you say power figures.
Not anymore, i did that almost a year ago. Dyno was in Marrickville, it has stocked turbo for last 10months but had a garret turbo replaced, injectors, normal fuel pump and computer. .
Edited by DAVID KIM
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
