guys has anyone got any idea what this ticking noise could be coming from my car? (other than a bomb)
it only happens sometimes... like tonight i filled up at the servo... took off... went to do a u turn and gave it a bit of stick round the corner... went to the lights and it started ticking! sounded like a metal ticking noise... quite loud.
then when i got home and went to check it out it stopped... well it stopped b4 i got home...
its happend a few times recently... seems to be after i give it a bit of a caining... but then again i took it around the rds just then and thrashed it and nothing... sounds normal.
https://www.sau.com.au/forums/topic/25977-ticking-noise/
If its a turbo gasket you'll here it eminating from around the turbo (obviously), and it'll gradually get worse.
Thats what mine did.
When it starts ticking again, get someone to rev it and stick your head near the turbo and have a good listen.
Though my noise didn't come and go as yours does?
https://www.sau.com.au/forums/topic/25977-ticking-noise/#findComment-551859
cool... hasnt done it for ages... oil is fine theres no leaks anywhere from what i can see... but eric ur suggestion sounds like it could have some merit as it did end up going away once the car was warmed up properly... mind u it hasnt happend since i posted this :)
https://www.sau.com.au/forums/topic/25977-ticking-noise/#findComment-551964
Originally posted by pushead
the noise comes on right behind the dash right? like a clinging ticking noise but after the car is warmed up properly its ok .
yeah i get that too
its like a creaking sound but once the engine is warm it goes away
what is that?
https://www.sau.com.au/forums/topic/25977-ticking-noise/#findComment-557001
I also get this ticking noise when I first start the car up from cold. Idles for about a minute then goes away...dosen't sound nice when it does it though...
It's not the lifters or injectors, very loud and distinct, and only happens when I start it in the morning.
I have read a few other forums and could it be the oil pump not working properly when it's cold?
I think we all would be GREATLY appreciative if someone knows what is happening...
Cheers
https://www.sau.com.au/forums/topic/25977-ticking-noise/#findComment-560394
I had a decent listen this morning (sat) and I think it sounds like the lifters or something in that part of the engine, because it stills make noise after its started, so possible not the starter motor or something....I have no idea really, take it to the experts when I can...
https://www.sau.com.au/forums/topic/25977-ticking-noise/#findComment-565133
  • 3 weeks later...
just to let anyone know still interested in this, I haven't been able to get to Ice Performance yet, but I found out (I think) why my engine was making a ticking noise; I was parking on a lean and the oil must of drained almost completely out of one side of the head and thus when I started it in the morning there was no oil there to lube up the cam and lifters, etc. until the pump got the oil up there. Have been parking on level ground since and not one ticking noise!!
hoorah!
https://www.sau.com.au/forums/topic/25977-ticking-noise/#findComment-587603
    • I also understand psi but apparently most things make more sense in kpa oil pressure being one of a few exceptions so im trying to learn ahahahah, I have no idea of the relief spring pressure tbh I thought 110 which is the absolute peak it hits was about right, I was thinking of removing the relief and making sure it is in good condition, I would just replace it but couldn't find a replacement for an n1 pump too easily but I could just be blind.
    • It certainly does make sense that there is just no oil to pick up, but I can go 3 or 4 gears of WOT and have no oil pressure issues too (I have no logs of this unfortunately) and I have a fair amount of oiling mods to try and help only thing I'm missing is a rear head drain which is potentially the most helpful.
    • speaking of the relief spring and noting this is one of those stupid times where I understand imperial (psi) but the graph is in metric (kpa), it looks like the oil pressure is a little low at full noise too, isn't the relief spring 120psi/830kpa?
    • No. All these dirty old Datsuns are shitboxes. Including the GTR.
    • Yeah well I was thinking...there is nothing that happens when you get off the throttle that should cause low oil pressure, its not like clearances suddenly change or and the relief spring would close and in any case the sensor is on the feed side....so more likely there was no oil available to pick up which means all the basic oil control stuff to: 1. keep oil out of the head (restrictors) 2. get it back out of the head when it gets there (external breathers/oil return, drilling out the block and head oil returns) 3. have more oil in the sump to pick up - larger capacity sump 4. have more oil near the pick up - baffles
