guys has anyone got any idea what this ticking noise could be coming from my car? (other than a bomb)
it only happens sometimes... like tonight i filled up at the servo... took off... went to do a u turn and gave it a bit of stick round the corner... went to the lights and it started ticking! sounded like a metal ticking noise... quite loud.
then when i got home and went to check it out it stopped... well it stopped b4 i got home...
its happend a few times recently... seems to be after i give it a bit of a caining... but then again i took it around the rds just then and thrashed it and nothing... sounds normal.
https://www.sau.com.au/forums/topic/25977-ticking-noise/
If its a turbo gasket you'll here it eminating from around the turbo (obviously), and it'll gradually get worse.
Thats what mine did.
When it starts ticking again, get someone to rev it and stick your head near the turbo and have a good listen.
Though my noise didn't come and go as yours does?
https://www.sau.com.au/forums/topic/25977-ticking-noise/#findComment-551859
cool... hasnt done it for ages... oil is fine theres no leaks anywhere from what i can see... but eric ur suggestion sounds like it could have some merit as it did end up going away once the car was warmed up properly... mind u it hasnt happend since i posted this :)
https://www.sau.com.au/forums/topic/25977-ticking-noise/#findComment-551964
Originally posted by pushead
the noise comes on right behind the dash right? like a clinging ticking noise but after the car is warmed up properly its ok .
yeah i get that too
its like a creaking sound but once the engine is warm it goes away
what is that?
https://www.sau.com.au/forums/topic/25977-ticking-noise/#findComment-557001
I also get this ticking noise when I first start the car up from cold. Idles for about a minute then goes away...dosen't sound nice when it does it though...
It's not the lifters or injectors, very loud and distinct, and only happens when I start it in the morning.
I have read a few other forums and could it be the oil pump not working properly when it's cold?
I think we all would be GREATLY appreciative if someone knows what is happening...
Cheers
https://www.sau.com.au/forums/topic/25977-ticking-noise/#findComment-560394
I had a decent listen this morning (sat) and I think it sounds like the lifters or something in that part of the engine, because it stills make noise after its started, so possible not the starter motor or something....I have no idea really, take it to the experts when I can...
https://www.sau.com.au/forums/topic/25977-ticking-noise/#findComment-565133
  • 3 weeks later...
just to let anyone know still interested in this, I haven't been able to get to Ice Performance yet, but I found out (I think) why my engine was making a ticking noise; I was parking on a lean and the oil must of drained almost completely out of one side of the head and thus when I started it in the morning there was no oil there to lube up the cam and lifters, etc. until the pump got the oil up there. Have been parking on level ground since and not one ticking noise!!
hoorah!
https://www.sau.com.au/forums/topic/25977-ticking-noise/#findComment-587603
    • Certainly. It is probably broken under the wire style clamp. At least that one is easier to get at than the front one.   Sounds like it isn't a major leak, I'd start with backing off the the water feed and return banjos into the turbos half a turn then tightening properly. Hardlines can still crack over time, either in the tube (particularly when turbos are changed if the banjo is siezed in the the tube) or at the brazed joins between the lines and the banjo fittings. A coolant system pressure test will reveal all. BTW you'd be able to get a sump without exchange, it will just cost more as they will have to source another stock one for the next customer. If you want to address the sump a much better option is something like this https://www.hioctanedirect.com/hi-octane-racing-sump-extension-nissan-rb26 that you weld in locally (and add the oil return fittings at the same time)
    • Pretty sure you are thinking of the throwout bearing there (which you should change when you change your clutch), when they are worn they will get quieter if you put your foot on the clutch. An input shaft bearing is turning/noisy at all times.
    • I’ll have more of a look into Recaros over the weekend. It’s taken me 2 days to figure out which Bride seats suit my application haha.
    • I am aware of their presence, but the product page looked like that conversion will eliminate the AWD capability. Fact remains it's kind of a hassle to send my oil sump halfway around the world and buying an extra one is expensive and unnecessary. Before I go hat route I'd explore more local options.    Would you recommend I just pull the engine and renew as many things as possible since I'm already having problems with some leaks? Would have to get an engine crane first though.
    • Are there any indicators that the vehicle is in limp mode?  Any dash light, or something.  Or is it just lack of acceleration?
