guys has anyone got any idea what this ticking noise could be coming from my car? (other than a bomb)
it only happens sometimes... like tonight i filled up at the servo... took off... went to do a u turn and gave it a bit of stick round the corner... went to the lights and it started ticking! sounded like a metal ticking noise... quite loud.
then when i got home and went to check it out it stopped... well it stopped b4 i got home...
its happend a few times recently... seems to be after i give it a bit of a caining... but then again i took it around the rds just then and thrashed it and nothing... sounds normal.
https://www.sau.com.au/forums/topic/25977-ticking-noise/
If its a turbo gasket you'll here it eminating from around the turbo (obviously), and it'll gradually get worse.
Thats what mine did.
When it starts ticking again, get someone to rev it and stick your head near the turbo and have a good listen.
Though my noise didn't come and go as yours does?
https://www.sau.com.au/forums/topic/25977-ticking-noise/#findComment-551859
cool... hasnt done it for ages... oil is fine theres no leaks anywhere from what i can see... but eric ur suggestion sounds like it could have some merit as it did end up going away once the car was warmed up properly... mind u it hasnt happend since i posted this :)
https://www.sau.com.au/forums/topic/25977-ticking-noise/#findComment-551964
Originally posted by pushead
the noise comes on right behind the dash right? like a clinging ticking noise but after the car is warmed up properly its ok .
yeah i get that too
its like a creaking sound but once the engine is warm it goes away
what is that?
https://www.sau.com.au/forums/topic/25977-ticking-noise/#findComment-557001
I also get this ticking noise when I first start the car up from cold. Idles for about a minute then goes away...dosen't sound nice when it does it though...
It's not the lifters or injectors, very loud and distinct, and only happens when I start it in the morning.
I have read a few other forums and could it be the oil pump not working properly when it's cold?
I think we all would be GREATLY appreciative if someone knows what is happening...
Cheers
https://www.sau.com.au/forums/topic/25977-ticking-noise/#findComment-560394
I had a decent listen this morning (sat) and I think it sounds like the lifters or something in that part of the engine, because it stills make noise after its started, so possible not the starter motor or something....I have no idea really, take it to the experts when I can...
https://www.sau.com.au/forums/topic/25977-ticking-noise/#findComment-565133
  • 3 weeks later...
just to let anyone know still interested in this, I haven't been able to get to Ice Performance yet, but I found out (I think) why my engine was making a ticking noise; I was parking on a lean and the oil must of drained almost completely out of one side of the head and thus when I started it in the morning there was no oil there to lube up the cam and lifters, etc. until the pump got the oil up there. Have been parking on level ground since and not one ticking noise!!
hoorah!
https://www.sau.com.au/forums/topic/25977-ticking-noise/#findComment-587603
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
    • ...oops. forgot the TCU end...
    • No I got mine from a friend that had fabricated one … but I had to fit it to my setup which was a hks turbo setup. His was a Garrett -7. So one of my turbos was not a flange for one side … then I had a leak in the welds I had to find a weld shut … in the end the setup was decent priced but I spent a lot to get it fitted. A couple companies I checked would make it but you’re talking 7-9k aud with titanium. No joke mine was 6-7k even second hand after I had to fit it in Hong Kong … labour is expensive here.
    • I'd just like to restate that I don't think anyone here is actually hating I recently sold a car part to a guy who was building a forged auto R34, with MV stall and aiming at ~450kw. I told him that I'm him, from the future and to stop after it explodes once. I told him I knew he won't listen the first time, and that's fine. But if my predictions do come true - Change direction faster than I did. I also said it's probably no coincidence that the dyno plot of a reliable turbo engine starts to look a lot like a N/A motor. :p
