I have seen a skyline (first time i have seen this one) in my street tonight.
It has no number plates front or rear.
I am wondering if it has been pinched and then dumped (the Hornsby area is not a common place for dumping cars but....)
so i am thinking should i report it to the police or not.
I would hate to report it if it wasn't stolen and cause trouble for the owner but
I would hate it more if someone did dump it but then came back to tow it away later or whatever.
Any way its a white 33 with mags on the rears and stockish rims on the front.
If you hear of someone losing one pm me with a description and if satisfied I will tell you which street it is on
https://www.sau.com.au/forums/topic/259808-stolen/
Report to the police, they will find a way to identify the car, but more than likely door knock the houses around the area to check for an owner.
If it's stolen, someone might get thier pride back, if it's not stolen, then you at least gave the police a bit of excersise for the night, no harm done.
B.
https://www.sau.com.au/forums/topic/259808-stolen/#findComment-4460627
I would check with the house that it's directly out the front of first, and if it's not theirs, then report it to the cops before it starts missing parts :P
It could be the difference to someone getting their pride and joy back in one piece :laugh:
https://www.sau.com.au/forums/topic/259808-stolen/#findComment-4460651
I would check with the house that it's directly out the front of first, and if it's not theirs, then report it to the cops before it starts missing parts :D
It could be the difference to someone getting their pride and joy back in one piece :(
Makes sense.
https://www.sau.com.au/forums/topic/259808-stolen/#findComment-4461891
B.
They will indentify the car by reading the rego label details....very very easy....unless rego label is not there due to smashed window...If window smashed, car can be unlocked, bonnet popped and vin plate read...If vin plate is not there engine number can be read..if engine is not there, check that car is still there...If no car or engine exists it may not be stolen because for a car to be stolen it first must exist....ddeeeeppppp
https://www.sau.com.au/forums/topic/259808-stolen/#findComment-4461919
    • Based off what you’ve said here, I think I’ve figured out a good bit of what I’ve done wrong -  So on the line going from the PCV valve to carbon canister, there’s a T joint that is pretty much right next to that lower port - I hadn’t noticed that the hose in the diagram was curved to attach onto the carb, so I was putting that line for the lower port onto the PCV line / carbon canister line instead. I’m going to have a flick through the manual again tomorrow and should hopefully find a diagram that’ll show me where that T joint should be connected to. Timing also 100% needs to be sorted out as well, should be able to tackle that tomorrow as well. Definitely feel like I should be on the right track now though.
    • The screw is for idle (pilot circuit) mixture adjustment. Else, I'm confused ~ the diagram shows 2 carby ports, and the intake manifold port, but you're suggesting the "2nd port on the back of the carb that isn’t mentioned in the diagrams" ...yet, both carby ports are shown...que?... ...in any event, that port should be connected, but if not (like it is now), it's unlikely to cause a backfire out the carby (it would introduce false air and give you a fast/lean idle) ...sounds more like timing issues/spark plug wire routing responsible for the backfiring.
    • That's fair, I can see both points. I get enthusiastic when I see the FS section has a new post and want to see what interesting thing someone is selling. Then I get deflated it's a bump of a 10 year old post. Ha ha
    • Couple of litres of moonshine from his southern cousins would do it...
