Brand new Nismo R34GTT front sway bar
$420 del
Reason for sale: Wont fit on my R34 GT-4 as i need a BNR34 one :P
Also Bosch 870cc injectors to suit R34 GTT. Bolt straight in but u need to run a positive and negative wire to the injectors from the existing connection (5min job) 3000k's old. Look stock.
$720 del
thanks Luke
Do you mean there are no plugs?
They got a plug which you plug into the injector and off that plug is 2wires (positive/negative). So you just wire up those from your existing connection.
If your serious PM me with your offer.
im sure the GTT it came out off had a modified rail, im 100% sure theyre the same shape as GTR ones as the GTT ones are skinner.
not trying to kill a sale but just letting ppl know before they jump on it.
gl with it mate.
http://www.skylinesaustralia.com/forums/R3...40-t110794.html
The blue stock injectors are indeed skinnier, but comparing the dephi injectors in that thread to your Bosch injectors, they look to be very similar in design and physical size.
Hope that helps.
Sway bar $400 pick up
Not sure about that Impedance stuff. Basically took them out of the car, bolted the old ones in and connected them up.
thanks Luke
