You've done a compression test and found a little drop in cylinder no1, so if it was me, thats where i would be looking.
Do a leak down test, theres a good chance no1 will fail the test which more than likely means headgasket.
All the other ideas are good, but when you've got a questionable compression test i would be looking there first.
but did they pressure test it hot? I know of a few now that did not show up under initial testing. car was puit back together and it happend again. crack was only opening up at temp. new head and the problem went away. it can sometimes be hard to diagnose. pourus block is less likely in my experience.
I was told it was x-ray'd for cracks.
An x-ray will show up a crack even if it's not hot right?
yeah you would hope so. but my advice would be get it leak tested HOT. people have been fooled before with 26 heads. the cracks is not always easy to find.
Yes, i've checked the water/oil mixture tap, flux capacitor and fusion reactor and they're all fine.
Any other ideas?
No sorry. You have checked everything.. you should pobly pull the engine out and get it fully checked.
could it be the block is cracked between where the head bolt goes into it and the water gallery on the outside of the bore.
99% of the time it's the cylinder 5 or 4 one EX side). The crack is usually very small, but grows. If you pull the head off you may not even see it as it starts sub-surface. Skim the block and you'll see it clear as days.
You get trace oil accumulating in your radiator, especially in your overflow? You empty it, it comes back?
The crack is small, but as the oil pressure is greater than the water pressure, it forces the oil through the crack into your water system. Over time, the crack will get bigger, and more will start on other head bolt / gallery places. The harder you drive, the faster it does it.
That is exactly what mine has done in the past
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
    • 😜 hopefully we get this instead of a new R36 GTR due to recent financial problems at Nissan. Nismo to sell a complete kit with RB26 and driveline. All starts making sense (ok maybe not) once the Nissan Leaf's (Leaves?) with stuffed EV motors/batteries hit the market cheap
    • Hi guys , have had allot of time for SAU and has helped me out heaps in the past so I thought I would give it a go , I have my QM1 white NUR for sale 1 of 156 examples built by Nissan. Serious personal messages please if interested and details will be provided , asking 500k
