The next thing you know, you'll be parked on the side of the road with a 500m long oil slick in your wake, with parts of the engine scattered all over the place because he thought you could advance your timing 40 degrees with 35 lbs of boost on regular unleaded whilst using the quality stock injectors.
Exactly. Everybody knows if you're going to do that you should run premium at least!
  • Replies 48
I am about to order an X-Force dump/front pipe and hi-flow cat. I've been told they are very good. I wanted stainless but they are double the price and apparently mild steel will last a bloody long time anyway. Agree?
Exactly what I have so agree.....having said that mine is showing some surface rust in a few exposed areas(at the bottom) was installed 08/2007
I would get a better cat though
Yeah I agree, but I went with stainless anyway.
The mild steel one will start to spot, then turn a disgusting shit brown, and then will start to flake.
The stainless won't.
In the words of Borat - " It's a nice, I like!!!"
how much difference is there with a decat and high-flow? noticeable performance?
also apparently u smell petrol alot more and get black fumes aswell?
Does it change the sound aswell?
You get flames, strange smells, and hurled abuse from Greenpeace with a decat.
Black fumes? You mean black soot and stuff? That's your car running rich. You see it with/without a cat.
you will get a nice tan on ya rear bar that is a bitch to polish out all the time just get a hi flow cat you might lose 1hp lol and the tree huggers will be slightly happy
go with the bellmouth stainless. get a better cat than the just jap ceramic highflow. they have an overpriced xforce metalllic highflow. but any metallic highflow cat will do a good job.
then get a tune
then go see your mechanic, and tell him he's sooo wrong. then do some skids as you leave. then go back and look out your window at him, and say "seeeeeee?"
then come back here and tell us how much better everything feels now that it can breath freely.
then go home and eat some food. it will taste better than ever before.
your girlfriend will look hotter.
your friends will seem less annoying.
then later on, prank call your mechanic.
but seriously, do it. its well worth it. theyre so damn cheap anyway. $200 for jjr stainless front/dump bellmouth?
based on a true story. names and places have been changed. vehicle was an r33.
Edited by Munkyb0y
turbo's hate exhaust back pressure! ANY back pressure is ALL bad.
any removal of bad gas flow from any part of the exhaust will make torque and horsepower.. and proabably ecconomy!
If your paying somebody to do work for you, and they dont go racing... find somebody else who does go racing!
Because they will be 150 000 000 steps ahead of the dude your talking to!
the more they know, the more chance that they will often charge more for work done,
but that will save you $$$ cos they actually know what they are doing and can advise you on the next logical step forward that suits your needs. You wont be buying parts you dont need and then trying to get rid of them to buy something else that 'might' work.
that help you?
So far 9 out of 10 people say fitting a dump pipe will give gains BUT.... i noticed that along with changing the dump,most ppl also changed the cat,front pipe or the complete exhaust at the same time.
I already have a 3" cat-less exhaust from the stock dump pipe back.What kind of gains will i experience if i go with a bell mouth dump? Also all these dump pipes u guys are referring to are 3" right?
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
