He is sore because his scam/false advertising has been found out. It is now publically known that he can't be trusted, and has lost alot of potential business nationally.
If evidence could be provided and he was up front and honest, plus treated people with some manners then I would believe he is a true business person. But his wording and manners suggest that he has obviously been short changed in the IQ department, especially thinking he could scam an Skyline car forum that he actually has a legit NISMO tunned/built engine in a GTR.
If he was serious, then paper work, dates of work done, updates to FAST and NISMO themselves would be able to verify the said car. Alas this has not been case, and as a business person I would have expected you to have fully researched the vehicle before importing or selling. So in the end it sux to be u!
  • Replies 197
Ok just to sum up incase I've missed something:
Question asked about a guy selling a car with a "NISMO Built engine". Turns out the guy selling the car can't back up anything... THEN has a go at everyone because we found it to not be NISMO built?
Have I missed something here???
Well screw it I'll have a go - I'm selling an R34 GTR V-Spec II Nur - it looks surprisingly like an R32 GTSt but trust me it has the number 2 in the engine number so it's a R34 GTR V-Spec II Nur ...
Anyone who says I'm wrong is a "tosser"
Good job Jim, good job.
tossers everwhere just as i thought , makes this fourm a tosser site ! should be tossers austrilia , not skylines austrailia
So Jim, you wont be posting here any more?...sounds like a great idea. :)
BTW It's Australia not "austrilia"
Clost this thread? Why would we want to do that now? Think I might leave it open a little longer sorry. You've been caught out trying to spin sh|t and now you're just dark you've been caught.
Mate if this is a tosser forum, why don't you "toss along" now and try and shaft some drift kiddies somewhere huh?
So you stated to the potential buyer that it was an S-Tune engine because it had an "S" in the engine number, then you claim that
"R33 GTR V-spec nismo Japan Built engine ,nismo Twin turbos, 4WD Special mid night purple duco RARE"
So are Nismo changing engine numbers now or are you completely FOS, actually by your previous comments you don't have to answer that.
Edited by D_Stirls
And here i was, reading boost like the good little enthusiast i am, and had much respect for OH Performance for building 2 very very awesome GTR's. And to find out, well, all of the above?
BAHAHAHAHAHAHA :/
    • Oof, I will forevermore have those shredded gears in mind whenever someone talks about showing mechanical sympathy towards their car. Thanks for the photos, fascinating stuff!
    • Curious to see how the SpeedTek stuff holds up
    • The holdups last year were drivetrain related. I had the car out right after getting the bearing issue resolved. Third launch and the car didn't move after releasing the clutch. It had sheared all the engagement teeth off the 1st gear.    Thankfully no other damage was done. I set an aftermarket gear beside an OEM gear and found that the engagement teeth on the OEM gear were much larger and better supported. Looking through my bin of spare transmission gears I found that there are two types of tooth on the OEM first gears - the larger tooth and the smaller tooth. It looks like most aftermarket gearset manufacturers base their design on the smaller tooth. OEM large tooth left - Speedtek, OS Giken, etc or OEM small tooth right Decided to give that larger engagement tooth a try. Pressed the ring off an OEM gear and sent it to a transmission manufacturer here in the States. They did their "faceplating" operation with my synchro ring on the Speedtek gear.   I reassembled it, took it back to the track and promptly destroyed the gear itself.  I'll rebuild this and use it as a spare - thankfully just first gear and the countershaft are damaged beyond repair. Definitely disheartening but my welded on engagement tooth ring held up!  Moved to Speedtek's dog engagement design as the gears appear to be much stronger. So far they have taken much more abuse at the track. Also scored a Stillway lockout from the Netherands for super cheap. It's for some other RB transmission so it took a bit of fabrication to fit but honestly a very easy job. I also had to heavily modify the gates as they were very different.   Then for some reason at the last test and tune a silicon coupler below the throttle blew off and took out the radiator and fan. Thankfully it was in the burnout box and not down track. This car is really beating me up - I still haven't made a pass in it. Ran it through the gears many times on the street but it keeps biting me at the track.  Currently in the process of replacing the radiator and remaking the throttle pipe to remove the coupler and use a cast 90 and a vband. I WILL get this thing down the track...
    • Covers most of the above points really. There's a few exceptions but most just see driving as an irritating but necessary task they must complete if they want to get anywhere on time. Also see it as a good time to show their awesome multi-tasking abilities on their mobile and/or doing their makeup.
    • I don't believe I posted pictures of the second oil pump pickup I added so here they are. Data shows it gets oil pressure up to the relief pressure much earlier in the RPM. Is that important? Not likely... This was just another attempt to fix the bearing issues.   I also heavily opened up the inlet to the pump since it now had to flow oil from two pickups. I believe the diameter increased about 1/8".
