Just a bit of research really, I'm thinking about building a media server for home, as will all the music and other media my laptop is nearly filled up and its only going to get filler, would run it over a wireless network with a wireless receiver hooked up to my plasma. blu-ray/dvd burner for recording TV/Foxtel etc.
Just wondering if anyone out is running one or has had experinces with them or would be interested in using one etc etc things like that. Not too sure on the actual specs as yet but would more than likely be running Linux or some sort with large storage capacity-- 2 - 4 TB in RAID config, more than likely just shut away in a cupboard some where in the house.
Seems like the perfect thing really eliminating the need for blu-ray recorders Foxtel IQ etc etc
So yeah if anyon e has any input I'd be keen to hear what you think
Edited by dirty_30
https://www.sau.com.au/forums/topic/259850-home-media-server/
i have just finished building my home theater pc, i'm using media centre on vista 64, with a decent TV tuner there is no reaons why you can record TV etc, also you should be able to pickup foxtel aswell.
i'm running an AMD 7750, with an asus mboard which has HDMI out 7.1 sound built in blah blah, have 4gig of ram 1TB of disk drive at the moment that will increase to 4TB, and a thermaltake d101 case. for me this works really well and the advantage of media centre is that you can use an xbox 360 as a media extenda which means the home theatre pc can hooked up to the big tv and the xbox to something else and two people can watch movies tv etc. my build cost me about $850 but that includes power supply DVD drive etc.
shit you managed to pull that off nice and cheap dude, I will be running linux preuly because it sucks less resources and i am comfortable that it will be stable enough to be running non stop constatly, will also be running it as an FTP and possible a webserver in the distant future, so it means I will have access to any of the files I may want or need no matter where I am, I plan on running it completely wireless to start off with atleast just to see how reliable and if 802g has enuf bandwidth to stream video etc flawlessly but with HD quality i am starting to think that maybe it wont, although time will tell i guess.
My HTPC uses an A-Bit Fatality FI90HD. Its got HDMI out and SPDif for Audio (as well as 5.1 analogue, but I haven't used it as my amp takes digital in). Ram is 8GB with a 1 TB green WD HDD. All sitting in a hollowed out VHS case which I'm currently fitting out with a SATA hotswap where the video tape used to go in. Got a BlueRay DVD/ DVD burner combo drive for playing DVD's.
Awesome thing was the VHS unit already had a power converter that supplied 6V and 12V at 250W so all I had to do was run the right wires with some resistors to get 3.3 and 5.5V to my MB and HDD.
Its fairly quiet and compact, which is what I want out of something that sits under my TV. Plus no one realises that its a HTPC cos of its casing ;)
I've been using XBMC all these days for interface on Vista 64, although I do wanna try out something like Media Centre too for its XBox360 connectivity.
Thats an interesting way of doing things bro. I was thinking about forking out for a proper Home Theatre case but im not too sure of their airflow capabilites and things like that. do you gus buy all your parts online? which site do you use if so? what programs do you gus us for media streaming and stuff like that, although if im going to using linux i guess this may not be applicable lol.
All up think it cost me like $400 in parts (already had a Leadtek HDTV tuner). I buy my parts pretty much exclusively from MSY and U-mart. Installed the TV tuner card using a PCI riser (adapter for servers that let you install cards parallel to the motherboard in case of space restraints).
also an msy and u-mart for me, basically the case is what cost me most of the money and airflow in the case is really good.
i have had vista 64 running for many months without requiring a reboot, MS seem to have their act together with their 64 bit OS, also windows 7 and media centre is one step better just trying windows 7 x64 at the moment will see how it goes over the next few weeks
where abouts did you find a copy of windows 7 x64 dude, ive looked and looked but only managed to find a version that hads to run in a virtual machine and that doesnt really appeal to me to test it out lol, ill have to go check out those sites this evening i think
Sounds like you need:
http://linuxmce.com/
Microsoft HAS stopped beta downloads.
I was permitted to try Windows 7, but did not download it soon enough and was cut off.
Pirate Bay has 32 and 64-bit versions as ISO's with activation code in the description.
Do a google search for "Windows 7 torrent"... simple.
Edited by iamhe77
    • If you don't touch the CAS, then you're fine.
    • Yeah, my moulds and seals are 32 years old now. I think I will continue to not use a pressure washer on it.
    • I hear the old "I'd never use a pressure washer on my motorbike" BS in the dirtbike community too.  The only people that have had a problem from using a pressure washer on anything are the people that aren't using them properly.  If you hold the wand any more than 45 cms away from pretty much anything (radiators, wiring connectors, paint, etc) you aren't going to cause any damage.  We've had detailers wreck moulds and seals on cars at work before and the only reason why is they held the pressure washer too close and on the one spot for too long.  If you have 5% more brain power than a detailer then you know not to not do that and you'll never have a problem.
    • I'm pretty much healed up post surgery so I spent another almost full day out in the shed re-arranging everything to make room for all of the shit that I've taken off the car.  I need to get everything off the floor and away from the car for when I start making a massive mess stripping off the remaining body deadener and then for the the painting process.  Almost got the shed to a point now where I feel I can actually start working on the car again (clean shed clean mind or something!).  Almost 11 years of accumulated car parts, building supplies, tools, junk, etc have taken a long time to get in some sort of order again!  Most stuff is now boxed up and in the back shed if it's not car related.  Most people would still be horrified walking into my shed but it's significantly better than it was before!   For those that saw my separate post the other day, yeah I ordered one.... This version- I convinced myself to stop being a clown, wake up to yourself and realise it will take you 5 weeks to make one by which stage you're over working on the car again...  Maybe I am getting on top of my "mental ailments" and making smarter choices.... $1450 delivered which will take my miserable half-dutch arse a few days to get over having spent that much!  If I don't have a use for it straight away after my car is off it I might even see if there is a "rental market" for them.  See if anyone wants to hire it for a period of time.  $25 a week or something like that.  I'll worry about that when my car is actually ready to come off it though as that might be a while away!! There's now no excuses now for not ending up with an underside you could eat off! Away for kids sport the next few weekends so hopefully can get the rotisserie assembled ready to go for the car to go straight on it the next available weekend.
    • I always use my Karcher, but it's only a little one that I picked up from Supercheap  The only issue I ever had with a pressure washer was when I was a kid cleaning coaches, they had a hi-po industrial sized petrol jobbie that would strip paint if you got to close I saying this, we have a fairly high power washer at work with a diesel powered heater that sprays water at about 60°c, it works great for removing old wax and road grime on the underbody after some foam cannon action, albeit from a "stand off" distance of a few feet
