  • 4 weeks later...
  • Replies 89
thanks mate, im all good now, just organising the cams side of things.
How are things looking Bozy, are we full up?
I'll ask Shell :banana:
Normally takes a few weeks turn around to get the membership pack up and running, I'll find out mate :banana:
  • 4 weeks later...
I may not be.
Have a severly cracked sump from a crown wheel and pinion explosion at oranpark last weekend. Since the sump is a one off dry sump Im kinda screwed for time to repair it.
Not to mention the aray of other shit thats in need of doing to it.
Anyone know if this day could be considered a CAMS OLT (observed license test)? Currently thinking about going thru the motions of upgrading to PC license.
Mr J.B.? Can you answer this :)
Ask him on the day?
Or send him an email, he has a link to it in his sig buddeh :cool:
And Stu, I'll bring glad wrap just incase, that'll hold...wont it? :P
Are you having dramas finding an r32 windscreen?
no, its the rear screen, never had one in the car, need one to make lexcen mould off, but running out of time....
i cant see having no rear screen as a drama but just waiting for Boz to let me know if its OK.
Might have to borrow one from Just Jap.
Ask him on the day?
:D
Or send him an email, he has a link to it in his sig buddeh :P
And Stu, I'll bring glad wrap just incase, that'll hold...wont it? :)
In a few days from now I'll get the EVO out on a track for the first time...can't wait!!!
Mate cant wait to see you out there!!! Finally after all these years your hard earned money and effort will come to fruition!!!! See you there champion :P
Chris I wont be out on sunday either, or for a while in that matter,
I have a few serious health concerns I have to deal with in the immediate future so the GTR is taking a back seat for a while.
Jay might take it to punch out a few laps but I won't be.
Hope you all have a good day out there Wednesday, really was looking forward to getting some quality laps in.
I will pick up the GTR on the way to Oran Brad and blow the cobwebs out for you :D
You just put your feet up and rest............actually you could put your feet up and rest while watching your car lol
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
