  • Replies 89
omg so buggered!!!!!!!!!!!!!
Firstly well done to Chubbs n Clapa achieving their goals. Chubbs proving that even hairdressers are fast and can steer with 54.9, Clapa steering the tug boat around in an impressive 53.6 and George (Demon) getting his EVO out for the first time punching out a 58.5!!!!
Now the failvia... well it seems that this mysterious issue is not so evident anymore... still some vibration under heavy brakes but i think that is just the pad/rotor... anyways it ended up getting around in a 51.7 which was happy about. Goal for sunday with all the stars and moons aligned i will get into the 50's....
A good alignment done and get the tyre pressures right she will be good to roll...
A big shout out to JB again for the day, Ben harper and george medeike (spelling lol) showing me how the car should be driven :whistling:
So what else is left to do.?!?!?!?!!?
Of course.. BBBEEEEEEEEERRRR!!!!
Its Ben Porter :D:whistling:
Yeah, what an epic day, plenty good cars, loads of track time, I love the south circuit!
the mx5 was keeping most of the cars honest! loved it!
Thanks to JB for today, totally worth every cent, I learnt so much, if it werent for these guys, Id be alot slower as I wouldnt have a clue how to drive this new thing properly!
Big ups to Eugene, George, Ando and Clappa also for doing great times and enjoying the day!
Now, my goal is 53's for sundays supersprint!
Sorry to hear all the bad luck Stu :D
What pressures do u need to run Ando and what have you been running?
At that Wakefield day (first time on semi slicks) I was running 30psi cold which rose to about 32-33psi hot but found out from the Yokohama dealer just near me that I should have started them at 25psi cold which will rise to 26-27psi.
Doubt I would have noticed any difference on my first day out in the car but ill give it a go at the OP GP day.
Ben - Champ i only adjusted the temp once all day lol.... i put 26 psi cold all round first session and came in with 33psi on drivers front & rear and 30 psi passanger front and rear so obvisouly there is a heap more load on the right hand side of car.... but yeah that was it for all day... just left them as that hahahahahaha just couldnt be arse fiddling as we had no air compressor, except clapas little cigarette lighter jobby which had less huff thana 70yr old hooker!!! :D
My moto if it goes, drive it.... meh to finer technical details... thats for this Sunday @ supersprint :( Today was R&D...
Huh what a day. Chris you shoul dhave the pic with headlights out...hehehehe. All was perfect with no events registered. PERFECT PRERFECT PERFECT.
Ian you are an inspiration mate, when I grow up I wanna be like you ...heheheheheh
Eug
LOL
Sounds like Eug has a crush on ando!
dont blame him though :D
Who took the other shot spando??
LOL, my car looks like a toy car in the one clappa took!
and for the record, I AM in front of that WRX :( (not he is catching me! :( )
    • I’m thinking that’s the route I’ll  go, thanks for the input!
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
