What an AWESOME day!!!!!
Thanks heaps to Ando, Chubbs and Clapa for helping me out on my first track day!!!! Can't wait for the next one...Looking to get some good semi's this time and maybe get rid of that stock suspension (if money permits)...oh no...actually got to replace those rotors!!!! BUT hang on ...first of all, I better spend some money on a detailer to get rid of all that dust and grass that's floating around in my car :D
  • Replies 89
LOL didn't that dusbuster work george!?? Ha ha
Was good meeting you mate! And after having jb in yr car your times dropped!! Well done!
LOL ..I got ripped off with that dustbuster!!!!! Yeah Bozman was awesome, he gave me some handy tips....I'll definately go faster next time because I'll put the bad thoughts out of my mind (i.e. thinking I'm going to write off my car and maybe hurting myself) and give it that 20-30% more... can't wait for the next track day
You guys sound like you had a ball!! :)
Spewn I wasnt out there :)
So did you all learn new things??
Great Times guys! Keep up the good work :)
yeah learnt that car control comes mainly from the feet, not the hands....
amen to that mate! now that you have experienced the rush of being on a track, those first time jitters will be gone for good and you can have confidence in your ability!
Just remember to drive within your capabilities and dont push or be pushed too hard... thats when things go ugly :)
I've been talking to Chubs and I'm seriously considering entering the June 12th Oran Park GP day...A little nervous though since I only just started getting the hang of the South Circuit and now I got some more track to learn . AND, I'm also seriously considering getting an EVO dedicated track car, but then i'd have to get rid of my daily EVO....
You should do it mate!! Seriously for $100 + membership this is by far the cheapest ever chance to run on OP GP!!!! To be honest OP South has the trickiest parts IMO. apart from the kink at the end of the straight, the rest is pretty straight forward!
LOL you cant sell the EVO already!!!! Just do some mods to your current one and you will be hooting around very quickly!!!
yeah i'll sort out my membership on monday and fax it through and then see if i can get the day off for the 12th June...
    • And if you want more power, more reliably, and cheaper, go get the Aussie RB... The 4L Barra and put that in instead.
    • No cats will keep discolouring the rear bar. Sends white paint a weird yellow stain. Cut and polish normally gets it out, but you'll be doing that every fortnight I found.
    • Both heads will be equally reliable or unreliable depending on what you do to them.  Stock the RB26 head will flow more. You have access to the stock intake ITB manifold on the RB26 cheaply which flows really well(1000hp+).   Arguably more aftermarket support for RB26, though in Aus we love our RB30 SOHC heads too.    The only downsides to the RB26 head is if you have a VL commodore and want to keep the SOHC look.  Where you may have an issue is drilling out the rb30 block for the bigger head studs but if you are building a big power motor you'd probably put bigger studs on the SOHC head too.  This is just about finding a good machine shop, sometimes easier said than done.  RB30 head worked can make big power just like a Rb26 head, so really it actually more comes down to what your preference is for your car.  People now even making billet versions of both.
    • 2630s work perfectly well. There is something to be said for just using the 30 head, as it saves all the pain of the conversion, still makes tons of power, still sounds cool, etc etc. 2630 will obviously make more power again, but the differences are not stupidly big. It really depends on whether you're racing for sheep stations or not. If it's dead serious, then it's a 26 head. If it's just for fun, it could go either way. But the 26 head and the effort to get it set up, etc etc, is part of the fun.
    • I've been building a 26/30 for a few years now. I've had the head built with all the good stuff. I had a 32 gtr but blew it up and yes its all going into a vl but im looking for some advice from some RB nuts on pros and cons on putting a 26 head on a 30 bottom end is it worth it Works are as follows Head -Extensive porting 1mm oversized supertech valves Supertech double springs Supertech valve guides Supertech titanium retainers Tomei solid lifters Tomei 270 x 10.25 cams Head drain Bottom end series 2 rb30 block Cp ceramic coated pistons Eagle rods Romac balancer Oil restrictions  O ringed blah blah spent a fortune And will get a girdle because the 30s arent used to handling that much rpm Nitto billet oil pump Hypertune plenum 6boost mani Refurbed astra pump thats the cover for it in the boot I did have a precision 6262 but sold it because drag car life. Currently building the ass end full 4 link floater rear end with a 2 speed  But the dilemma i have is my mate rekens I should just stick with the 30 head for reliability. Has any one had any issues with mounting the 26 head ie compression blowing gaskets etc. Just looking for some advice from people who have gone down this route. Here's some photos. Blew the oil pump in the gtr and decided to rip the motor out at the time and do a full build only to find it had been a repairable write off so went down this path.
