  • Replies 89
omg so buggered!!!!!!!!!!!!!
Firstly well done to Chubbs n Clapa achieving their goals. Chubbs proving that even hairdressers are fast and can steer with 54.9, Clapa steering the tug boat around in an impressive 53.6 and George (Demon) getting his EVO out for the first time punching out a 58.5!!!!
Now the failvia... well it seems that this mysterious issue is not so evident anymore... still some vibration under heavy brakes but i think that is just the pad/rotor... anyways it ended up getting around in a 51.7 which was happy about. Goal for sunday with all the stars and moons aligned i will get into the 50's....
A good alignment done and get the tyre pressures right she will be good to roll...
A big shout out to JB again for the day, Ben harper and george medeike (spelling lol) showing me how the car should be driven :whistling:
So what else is left to do.?!?!?!?!!?
Of course.. BBBEEEEEEEEERRRR!!!!
Its Ben Porter :D:whistling:
Yeah, what an epic day, plenty good cars, loads of track time, I love the south circuit!
the mx5 was keeping most of the cars honest! loved it!
Thanks to JB for today, totally worth every cent, I learnt so much, if it werent for these guys, Id be alot slower as I wouldnt have a clue how to drive this new thing properly!
Big ups to Eugene, George, Ando and Clappa also for doing great times and enjoying the day!
Now, my goal is 53's for sundays supersprint!
Sorry to hear all the bad luck Stu :D
What pressures do u need to run Ando and what have you been running?
At that Wakefield day (first time on semi slicks) I was running 30psi cold which rose to about 32-33psi hot but found out from the Yokohama dealer just near me that I should have started them at 25psi cold which will rise to 26-27psi.
Doubt I would have noticed any difference on my first day out in the car but ill give it a go at the OP GP day.
Ben - Champ i only adjusted the temp once all day lol.... i put 26 psi cold all round first session and came in with 33psi on drivers front & rear and 30 psi passanger front and rear so obvisouly there is a heap more load on the right hand side of car.... but yeah that was it for all day... just left them as that hahahahahaha just couldnt be arse fiddling as we had no air compressor, except clapas little cigarette lighter jobby which had less huff thana 70yr old hooker!!! :D
My moto if it goes, drive it.... meh to finer technical details... thats for this Sunday @ supersprint :( Today was R&D...
Huh what a day. Chris you shoul dhave the pic with headlights out...hehehehe. All was perfect with no events registered. PERFECT PRERFECT PERFECT.
Ian you are an inspiration mate, when I grow up I wanna be like you ...heheheheheh
Eug
LOL
Sounds like Eug has a crush on ando!
dont blame him though :D
Who took the other shot spando??
LOL, my car looks like a toy car in the one clappa took!
and for the record, I AM in front of that WRX :( (not he is catching me! :( )
Guest
    • There are certain tasks, like replacing head gaskets, where it is very much best to already know what you are doing, and if you are not already an expert, then the next best thing is to have an expert around to help it get done. Little annoying checks and steps that are easy to forget or not interpret the results of properly, etc etc. It is hard to convey that to someone as a lesson prior to taking on a job, because there can be a whole list of "if you see this then it means that", or "if this is what you find then you will need to do these other 4 steps first". All the little bits of knowledge around sealant choice (ie, sealant at all? or no sealant? sealant only in certain parts of the gasket? sealant for this type of gasket but not that type of gasket? etc etc) cleanliness checks and methods, surface straightness and finish checks and methods, etc etc, all combine to mean that people who have done many of the same type of job will struggle less to get a good result than someone who hasn't done it before. I've been around this stuff since forever. But I will still consult with my expert(s) before taking on the big stuff with higher risk profile.
    • Well if I end up having to do the head gasket I will certainly find the necessary tools and instructions before beginning... Let's hope it won't come around.   Definitely. Depends on the job but I think "if you want it done right, do it yourself" applies almost every time
    • Can you at least move to a location without so many ladders, black cats and mirrors precariously propped up ready to be knocked down? Or buy yourself a 1 ton bulker bag of salt to drag around with you. Just, you know, sling it over your shoulder?
    • Meh, what's the worst that can happen? If is is supposed to have a washer, and: the spring retainer seals reasonably well on the surface, maybe just allowing a little bleed of oil out, and the spring does not coil bind when compressed that little extra bit, then the end result will be slightly higher relief pressure setpoint, and no other noticeable effects.
    • Weirdly I see a flat washer on aftermarket pumps but as you said it doesn't seem like new OEM pumps have it. EPC doesn't break out the regulator as a separate component either. I'm guessing if the pump came that way it's safe to use as-is.
