S14 manual conversion kit:
s14 abs tailshaft
s14 clutch and brake pedals
s14 master/slave cylinders and S14 damper/lines
s14 speedo drive
s14 X-member and mount
SR20det flywheel and clutch, throw out brg and fork
all bellhousing, starter, mount, flywheel, clutch and slave bolts
NO console surround or boot.
Perfer pick up
$400 No Box
SR20 Used manual gearbox: Not Neg
1x s13 sr20 5 speed manual
N/R, 2nd gear synchro crunches on downshift
new bearings and front housing fitted 18 mths ago
$300
S14a rear bumper:
pearl white, aus spec off s2
$100
S14 HKS rear coilovers:
HKS/kawasaki, 30 way adjust damper, pillowball tops
$200
S14 16' alloys X4:
16x6.5, few marks, straight, 4x RWC michelin tyres
$150
S14 - S15 JJR Camber arms:
Rear upper, Good condition
$100
S13 J's headlights:
dual square, glass removed, reflectors req rechrome, plastic's covers req repair
$200
S13 R180 3x2 diff:
out of ps13 sr20de
$50
Random other bits: !!!No stereo or console surrounds, lca's, brakes or hubs!!!
S14 dash plastics: vents, glove box and clusters from $5
S14 single airbag dash $40
S14 radiator and shroud manual $150
S14 s1 rad support $150
S14 Front X-member $80
S14 abs bmc and booster $80
S14 abs pumps s1 or s2 $30
S14a leather steering wheel inc. airbag $100
S13 boot trim complete $40
S13 radiator + shroud manual $100
S13 sr20 front calipers, lines and rotors $60
S13 and S14 sr20 engine parts From $5
Located Gold Coast,QLD
Prefer pick up
Sam 0423 648 114
[email="
https://www.sau.com.au/forums/topic/259874-sparrows-garage-sale/
4x 18x7.5 +38 5/114 ENKEI 5 SPOKE rims + Hankook Tyres $1600 suit skyline,stagea,mazda,toyota
2x 18X8 +32 2x 18X9 +36 5/114 SPEEDY CHEETAH Rims + Federal Tyres $1100 suit skyline,200sx,toyota,mazda
Or Swap both sets for good GTR offset jdm rims + tyres to suit stagea rs4s
S14 Ganardor mirrors: genuine electric, painted black $450
Better photos soon
Edited by RED513
Rear coilovers, Rear bar, speedy's, camber and tension arms, s14 rims & Gearbox Sold
S14 ganadors, enkei's and S14 manual kit still available!
+ s13 r180 diff & J's h/lights!
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
