  • 5 months later...
How have peeps gone using 98 Maxima cruise control stuff? especially with the steering heel? I had the complete kit and kaboodle from the wreckers for about $40 including the ecu for the cruise. located the wiring diagram for maxima...
Ended up turfing it some time ago as then relised i would need the mounting boss/clips (whiteplastic) from the 98 maxima sterring wheel assembly... then there's the airbag... i put it in tooo hard basket.....
although was at same wreckers last week with about 4 decent maximas with all the gear, so my interest has been sparked again! so i picked up the set/acc/on button, which fits the stagea steering wheel perfect on right hand side + the on off button from the dash which suits the blanks/spares on the stagea. now to go back and get another ecu/vacuum pump and the engine bay loom.
How have peeps gone using 98 Maxima cruise control stuff? especially with the steering wheel wiring ?
After checking the thread again...was at same wreckers last week with about 4 decent maximas with all the gear, so my interest has been sparked again! so i picked up the set/acc/on button, which fits the stagea steering wheel perfect on right hand side + the on off button from the dash which suits the blanks/spares on the stagea. now to go back and get another ecu/vacuum pump and the engine bay loom.
  • 2 years later...
Hi All,
Meant to revisit this ages ago.
In the pics you'll see all the necessary items to install cruise in the stag, with the exception of a relay.
However, note the clock spring in pic 2&3. It only has 8 pins, so if this is used, would have to make a choice
between cruise or the tiptronic buttons on the steering wheel.
Has anyone come across a nissan clock spring with say 16pins?
Or 98-2001 Maxima steering wheel with cruise/audio buttons or cruise/tiptronic as this I assume will have the clock spring with 16pins (thereabouts).
Cheers,
Pete
ps. if i can locate one/do a successful install, i will post up a DIY/How To, with pics.
  • 5 months later...
Hey mate thought you might be interested. I completely installed the cruise control system in my rs4s from an a32 maxima. Check my topic posted afew days ago.How many wires in the stagea clock spring are used for the tiptronic functions?
  • 6 months later...
Hi Guys,
I've ordered an NM35 from Japan and want to equip it with Cruise Control and a bunch of other stuff when it gets here. I found what appears to be a genuine unit from Sinergy Motorsport, see below:
https://www.sinergymotorsports.com.au/cart/products-page/cruise-control-nissan-stagea-m35/
Does anyone have any experience with these? If it is the stock system what mod do I have to perform to be able to set the speed above 110km/hr?
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
