hi all
this is my C210 '78 coupe ive owned since 2000. IT IS NOT FOR SALE
Absolutely stock, i am the 2nd owner (lady owner originally)
5 speed, no air/steer. cream interior. straight as an arrow apart from a small dent behind the drivers door
have stove top tail lights (they cost a bit, and very rare!) the engine runs on 4 cylinders at best and she doesn't
have enough compression to go into 5th hehe
i wrecked a c211 4 door. the body was beyond repair. it was completely rusted and would not have suited a restoration
from it i got 4 wheel discs, injected L24 w/5 speed, power windows, air/steer. the front light assembly and dash. (dash is much nicer and will go into the coupe, as will air/steer and brakes)
some of this stuff i may be selling in the near future. ill keep you all posted.
https://www.sau.com.au/forums/topic/259915-my-c210-coupe/
stovetop tail lights.
My collection of C210/C211 stuff. more to come from the farm
the only dent in the car. previous bog attempt failed!
front bumper isnt bolted down. needs to be repaired.
the only bit of rust in the whole car
nice n straight!
ive got a couple of more boxes to get from the farm. ill have them home real soon and ill organize what i will keep or sell
keep ya's posted and thanks for looking
https://www.sau.com.au/forums/topic/259915-my-c210-coupe/#findComment-4464672
those stove tops are EXACTLY the type i want for my car. i found a pair on ebay and won them back in jan 3rd. after not receiving them for 4 weeks, i got a little bit suss and turns out the guy took my money and did a runner. luckily i bought them with paypal and they were able to get my money back. but i only got it back this week.
unlucky (again)
https://www.sau.com.au/forums/topic/259915-my-c210-coupe/#findComment-4464708
unlucky (again)
unlucky alright. i got mine about 2 years ago... but i found my first set in japan a couple of days before the sept 11 attacks through the uk & jap sites. took about 4 months of emails and searching. all laid out on the floor, ready to go to my door for $650, then the attacks happened and the price went to $1000 (p/h went up), so the deal fell thru.
dont give up, you'll get them!
https://www.sau.com.au/forums/topic/259915-my-c210-coupe/#findComment-4465425
i dont have any connection with japan unfortunately. nor do i 'know a guy who knows a guy' lol. nor do i know where to look :) well except ebay, but that hasnt gotten me very far. any pointers?
https://www.sau.com.au/forums/topic/259915-my-c210-coupe/#findComment-4465891
i dont have any 'connections' but these are the links that i used. mind you, these links are 10yo.
www.geocities.co.jp/MotorCity-Circuit/5350/
the link above works. these links im having trouble loading. give it a go. run the sites through babelfish to translate
http://www.teletranslator.com:8080/?AlisUI...r/myskyline.htm
http://www.teletranslator.com:8080/MotorCi...p;AlisUILang=en
http://www.teletranslator.com:8080/~goodr/...s_ex/ns_toolbar
http://www.teletranslator.com:8080/?AlisUI...1645/index.html
hope this helps.
and here is a custom C210 ute!
Edited by NightMonkeyII
https://www.sau.com.au/forums/topic/259915-my-c210-coupe/#findComment-4466343
  • 2 months later...
hey dude, firstly just wanna let ya know that ur car is wicked, but i think u might be suprised that i have the exact same car but 4 door.
mine is also metallic green, the paint is slighty faded, but still in very good condition for its age.
ive got a recond L28 in it now, but stil have the origional L24 carby engine.
5 speed, aircon, power steering, but no electric windows :)
the car is complete with the factory pressed steel mags with veyr minimal rust in the whole car apart from underr the boot rubber and next to the rear left tail light.
sweet ride man, ill try get some pics up of mine! have a browse!
peece :):P
https://www.sau.com.au/forums/topic/259915-my-c210-coupe/#findComment-4605545
excellent!. sound like my old four door i had years ago. 5 speed, extractors and lukey exhaust right through, holley 180, air cond, no power steer, and very thick sway bars. silver in color, i discovered structural rust that rendered the car rooted! leaked heaps of water into the cabin, but sounded and went well. ive got my coupe fairly well stripped, will post progress pics asap
https://www.sau.com.au/forums/topic/259915-my-c210-coupe/#findComment-4605822
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
