Hey all
Got and installed my new intake on the V35.
I also put a new K&N panel filter in. Its the same model number as a VS 3.8 litre commadore. A360.
It looks pretty good to me, i might use a longer piece of silicon pipe for the end nearest the box, but just to neaten it up a bit.
The sound is way better in the higher ranges and when the throttle is nice and wide open.
Down low, its great, no more noise than stock until you give it a hit.
Photos attached and a video with a digital camera.
The sound quality isnt great, but you'll get the idea i hope.
(I dont know how to add the video to the thread)
Edited by V35 Matt
https://www.sau.com.au/forums/topic/259921-new-intake-on-the-v35/
  • Replies 94
Posted Images
got the pipe off ebay. No idea what brand it is, but i like the stainless look rather than the plastic look of the z pipe.
Self install with a mechanic mate. But having seen it installed, anyone could do it without any worries at all.
Took 15 mins, as we removed some of the excess plastic from the box and the intake.
Now the muffler to install and it'll be complete as far as external mods go.
Hope to get better video over the weekend of the engine and the sound of the car going past.
wanna ask for some suggestion.. i heard somewhere that the oem 350z intake pipe is actually better, compared to stainless steel pipe, due to reason that stainless-steel pipe gets hotter easier and faster than plastic, so actually hot air are being suxked in..
Anyone can help to explain if this is right or wrong in anyway?
I do kinda agree if someone told me plastic gets hot the same way just like stainless steel... but it does also get colder faster than plastic rite?
this is the reason i still cant decide wat kind of intake i should buy and install on my v35.. ;)
The Truth from 350z is that the Intake is already a great design on 350z, They just need to use a Drop panel filter and it's already Perfect. But if you want the Noise you can go for the POD (ie JWT pop Charger). also most of the tuner in japan uses the SS tube like Matt did. So about the heatsoak i'm not too sure, if you want can just heatwrap it or so.
myself uses the CF Tube on mine with the K&N Drop in Filter.
to be honest if you want to get the Z tube. at least get the one from US version. It doesn't have that Water Collector/Resonator on the tube like the Australia version does.
Cheers
Is that what it is!?? I asked the question on the g35 forum a while ago and no one could tell me exactly what it was or how come theirs didn't have it. Oh well...still does the job I guess.
Yeah, that stupid appendix thing is a resonator. The US models didn't get it. I am pretty sure the Japanese cars did. It's for NVH.
Honestly, if you bought a 350Z you shouldn't be allergic to a bit of induction noise.
Yeah the stainless steel pipe does get a bit warm but I think it would be hard to notice a difference in power compared to say a CF one, would probably only show up on a dyno over a number of runs. I should probably feel how warm mine gets now since I put the Kinetix Plenum on, would help a bit I imagine as that isn't metal.
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
