Ok well the good things are that they go straight in, handy if you have a full exhaust system including a dump pipe that goes to the factory 6 bolt flange. Only issue ive heard is that they are a little bit down on power due to the redesigned exhaust housing that lets them bolt in?
Water lines need to be adapted etc but that is a relatively small issue.
Vehicle - 1997 Nissan Stagea RB25DET Auto
Modifications -
Aftermarket exhaust system from turbo back
600x300x76 Greddy FMIC
Turbosmart Boost Tee
Turbosmart dual port BOV
CAI fed completely shielded K&N pod filter
Pretty certain i would have to step up to an E-boost too or other type of EBC in favour of the Tee, and upgrade injectors as ive seen that these peak out duty wise once you start running larger turbos.
I dont really want to have to pull the engine down or even take the head off at this stage, is the main thing. Should i look at cams? even just the exhaust cam or an adjustable cam gear to help lower the spool RPM?
Thanks guys.
EDIT - the car in question is NOT the 260RS in my signature. cheers.
I thought you were currently Nissan-less?
This the same? http://www.gcg.com.au/turbo/ViewProduct.aspx?ProductID=202 pretty much GT2835 Pro S spec, cant check inabox, capped haha
I dont have the 260RS anymore... it was sold to fund the deposit on a house and the restoration of an old aussie muscle MACHINE haha..
Im having to drop back to an RSfour. Trying to sneak some modifications in under the missus' nose.
R31 Nismoid no they use a different rear housing to allow it to bolt directly to the 6bolt flange. Ive heard this is what causes them to be a lil laggy but ive seen the two (original and HPiaB versions) next to each other and i dont see anything that would greatly impede the flow of exhaust gasses...
WOuld it be a better option to go something different completely, and run a different dump pipe to suit? Im just chasing a low mount replacement that offers decent power and power delivery without creating to many hassles. now is that TOO MUCH TO ASK!?!?!?! GOSH!!!!
sorry....
Ryan im picking up an RSfour next week that is pretty stock standard save for some wheels and suspension. Fresh canvas.
Well buy it if you must - but when you come back posting about boost control problems dont say people didnt warn you. Two people have in two posts... its not good odds.
If you dont want hassle... garrett rear housing... its not hard.
then buy dump to suit, again, not hard. it all has to come off to be fitted
be happy
be happy
Do they come in IW and will they fit under a stock turbo heat sheild?
Bobert, link me the new one ;)
[link]http://www.horsepowerinabox.com/HPIAB2/category12_1.htm[/link]
Its the 7th turbo down the page.
Boost control problems would be a wastegate issue nismoid? Thats why you recommend an externally gated unit...?
Not sure if they fit under the shield ryan - they are a lil bigger.
The questions were for ash(as he had a GT30 i think), and the link request was for the stag haha
No, boost control issues with non genuine GARRETT housings...
Nothing to do with external gate
So do garret make an internal wastegate housing?
and do the GT3071/76 fit under the standard turbo heat sheild?
Have to search under GT3071R IW or GT3076R IW , I'm told the propper GT30 integral wastegate turbine housings were developed here in Australia and look very similar to the turbine housing on Fords XR6 turbo cars .
In that case they're used on a GT3582R , personally I think they are intended to be GT30 turbine housings but some are machined out to fit GT35BB turbines/turbos .
People here like Mafia/Cubes are using them and I posted pics of the bare housings when they became available in Sydney a couple of years ago - don't have the link sorry .
I would always use a genuine turbine housing given a choice because the manufacturer designs the housing to work with their turbine - they are a matching set say like a 16" wheel with a 16" tyre .
I'm not going to rag anyone but it's easy to see where producing a generic turbine housing and machining it to suit various diameter turbines will cause problems , because like the 16" rim example you may guts a 15" tyre onto it but its not the way the engineers intended it to work .
The usual problems with generic turbine housings is elevated exhaust manifold pressure (TIP or turbine inlet pressure) which shows up as what people call "boost creep" - the wastegates inability to bypass sufficient volume of exhaust gas to "throttle" or control turbine speed (compressor as well) and therefore boost pressure .
The best gas flow situation is to use the turbine/turbo manufacturers matching family of turbine housing but even then the housings A/R ratio has to be right as in not too small .
Search here under GT3071R and GT3076R because there are some long strings and lots of peoples R and D you can benefit from .
Beyond the scope of this thread but Garrett is tooling up to make a bolt on version of the GT3071R and GT3076R for the the Evolutuion 10 Lancer . The big news is that their turbine housings will be twin integral (internal) wastegate and twin scroll available in 0.73 and 0.9x A/R ratios .
Sadly the mount flange style is not split "T3" but if adapters or a custom manifold were on the cards it'd be real hard to beat on a road car .
Hope this helps , cheers A .
i have a 3076 .82 IW on my 25. got told by the company i bought it from i'd have massive boost control issues with IW but i gave it a go anyway. i think the most important thing is having a big bellmouth dump on it. i made one up with a mate with lots of flow around the gate area and with a 12psi actuator it holds 12psi perfectly
the "bolt on" gt30s have a machined out rb25/vg30 rear housing to make it bolt on. even machined out to their max they're still not really big enough to work properly. definately get a genuine garrett rear housing.
and the stock heat shield fits with some modification, i just bent myne a little bit and screwed it onto the manifold shield, works pretty well
Has anyone used this one from tweakit.net? http://www.tweakit.net/shop/product_info.p...roducts_id=6598
Its got a garrett 5-bolt dump rather than the Nissan 6-bolt dump. Would that help with the boost control issues?
Trick is to run the .82 IW.
If you wish to run the .6 or .7 RB style 5 bolt turbine housing or .6 Garrett xr6t style you will have issues with boost creep.
To help with boost control the best method is to run a nice big bell mouth. The splits tend to improve gas flow of the turbine wheel while due to the 'typical' split design it reducing the available area 'around' the wastegate flap.
As the flap opens it partially blocks the dumps wastegate pipe, not good for a turbo that is running a flapper sized borderline for its application.
HPIAB I can recommend; tweekit have never got back to be on several occasions when querying their products so sadly I cannot recommend them.
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
