  • Replies 499
Posted Images
oh dear god.......................... :huh: what am i supposed to do now?
Just drink enough so you don't remember the night before :P
That way what you don't know won't hurt you. :P
I have broached the subject with the missus (unsuccessfully initially), but will work on her further. Biggest problem is we have a couple of other things on that she would then have to go to with the little one by herself.
What day/time is everyone thinking of cruising over, and what is the likely return day/time? I assume we would much prefer to cruise over as a big group.
well some people are going to come up saturday and stay saturday night, while i think a few others are coming up sunday morning for the show.
presentation is at 3.00 so hopefully if they are running on time should be able to get out by about 4ish
I wont be entering. ill come down and have a look but not entering. My car is black with black wheels. Not really show worthy. YET.
:P
hahaha then you should see my car
dude
pleasesssssssssssssssssssss enter!!!
i will sooo be like your best friend! :blink:
I thought that you were my best friend :rolleyes:
