Got it off BIGPSI, it gave me rev and speed limiter off, now i'm running too rich on Sam's dyno, could make more grunt if it's tuneable or second option is whack on a big sucker but that invole bucket of $$$ where most i can have is bucket of snails in my garden .:)
Anyone have or know anylink, chances to get my hand on the software is 0000.....000001% but its' good to know what they do.
Thanks.
https://www.sau.com.au/forums/topic/26001-anyone-knows-about-these-guy/
West - let me know how you go.. I have a chipped ECU in my car and as dyno'd by same from BMT, it pulled 174kw ( boost controlled to .7bar by chipped ecu). Other mods are 3" cat back zorst, pod filter and bov.
Seems as if it has advanced ignition, changed fuel mixtures and played with boost. My main concern is running rich.... as I do get the odd POP at cruising revs.
So, really its pretty good apart from running a bit rich ... which sounds like your problem West
yer, I remember your car West on the dyno day ages back. With the small cooler, and minimal mods you were getting some pretty sweet figures.
Mine has speed limiter removed, but can't find any form of external device that has done it. I pulled apart my ECU but looks stock as inside.
Your other option West is just to chuck a S-AFC on and play with the modded maps of the ECU to lean it out a little more at various points. Might help, then again, might do little ;)
jet33 was doing that on his old car before he realised he had a chipped ECU :(
Originally posted by predator666
Your other option West is just to chuck a S-AFC on and play with the modded maps of the ECU to lean it out a little more at various points. Might help, then again, might do little :)
thats something i was thinking of... but then defeats the purpose of the chipped ecu i think.. oh well.. that or power fc.
    • I just got to work and skimmed through 61508 and 61511. I was surprised the CSA adopted both, but neither are enforced. To recap what I read, it states that in a perfect world, they should be segregated but they acknowledge that this is not industry standard and clearly mention that they allow mixing of safety and non-safety. 61511 also mentions software segregation like AB does in their safety PLC's.   Now if only I could go back to control, let alone safety over comms. In my current line of work, we're only allowed monitoring over comms. Everything critical must still be hard wired.
    • I've unfortunately never been as they're on the complete other side of the continent and another country that isn't currently letting us in as easily as they use to. I even heard their stop signs over there actually say "Stop" instead of "Arret". If I decided to trek the 48h drive, I wouldn't know when or where to stop haha. Whenever I order parts from UP Garage, I order from Japan as it's cheaper. Same with GKTech... oddly enough, it's cheaper shipped from Australia then it is the US.  UP Garage Japan operates their US leg though, unlike Tomei. If Tomei JPN had the power to close down Tomei USA, I'm sure it would be done in a day. They're two completely separate entities. Tomei JPN messed up somewhere originally agreeing to its creation and got sacked big time.
    • I asked someone about this and he told me about the Audi 1.8T engine. But I think it would be difficult to swap
    • I don't know that machine specifically, but I'd personally go for something with a little more kick than 130amp. Around up to 180 would be good. At the 6mm range, you're really pushing the machine hard and don't have a long period you can run for with out needing to give it a rest. Lots of MIG machines come with a regulator and hose. A lot will come with a starter roll of wire too, but it isn't too expensive to buy. I'd recommend NOT buying a massive roll too, as you don't want it sitting around FOREVER in the machine between uses and potentially going to shit. For thin sheet metal, get a roll of 0.6mm if you're doing over 3mm and above, switch over to 0.8mm wire. Even by 2mm you'd probably really want to switch. As for gas battle, it's all swap and go style now. You'll pay a bottle deposit, and then X amount to swap for a full one. I think it's like $200 or $300 for a D Size bottle upfront as "deposit", and like $110 to $150 per swap. My D size CO2/argon bottle lasts a fair bit of welding on the MIG. And I run an E size bottle on the TIG. For DIY MIG, stick with a D size bottle. If you really start to get into a LOT of welding and doing it really regularly, then upgrade. If you're like most DIY car guys, one D bottle will last you 2 or 3 years easily. I think I've been on my current bottle about 5 years. It is starting to get low, but I've been smashing it a lot more the last 6 months.
    • SR20s came with cars like the Bluebird and Primera, but the RB20 never came. The ones in Turkey were either brought in specially or from abroad. That's why RBs aren't as common as SRs. And if a part breaks or I need to replace it when doing maintenance, it's harder to find parts for RBs.
