Hi just a quick note to let those interested know that Sport Comact Drag Racing will be on at WSID next weekend. We will be debuting our new set-up and this will also be the first time the car will race under the Godzilla Motorsport team. I see a couple of Skylines in the list including our own Anthony Espinola (Guilt-Toy). Hope the weather is ok as nothing breaks a drought quicker than trailering my car to Sydney to race.
Hope to see you there.
https://www.sau.com.au/forums/topic/260024-compak-attak/
  • Replies 100
Big event...already almost 200 entered.
http://www.sportcompact.net.au/compakattak...tlist/index.php
Im doing some testing on friday night to get the suspension sorted. Ill be running pump fuel on low boost though so i wont be setting the world on fire. Just mainly going out and having a bit of fun getting used to the new set-up.
https://www.sau.com.au/forums/topic/260024-compak-attak/#findComment-4467540
dammit... ill be in sydney friday and saturday, im the special guest at a 1 yr olds birthday, but gotta leave early sunday morning so mrs can get to work.
thrash em fellas... look forward to the youtubeness.
cheers
Linton
https://www.sau.com.au/forums/topic/260024-compak-attak/#findComment-4468232
It's a one day event, Dave :D
+ 1 for pit crew if needed.
grease or drinks...all good :P
Im testing friday night...i think thats what he is refering to.
these late night last minute jobs are killing me...just got home...2am.
https://www.sau.com.au/forums/topic/260024-compak-attak/#findComment-4470359
If im your bitch...then smack me like a bitch.
Is your mega buck engine going to make your car go faster than a stocker you get from the local wrecking yard?
Let the smacking begin.
Yeah Mr "im the fastest twin turbo in the world" did you have to suck off Mr King GTR for a big single turbo upgrade so you can be cool like us ?
Can't wait to see you race your dodgy backyard built small block rb26 that was tuned by the dodgy tuner from the ghetto
Bring it.
https://www.sau.com.au/forums/topic/260024-compak-attak/#findComment-4470761
Bring it.
Big block...small cock.
https://www.sau.com.au/forums/topic/260024-compak-attak/#findComment-4470794
Paul, have you got the car on the trailer already? as it's raining down here at the moment. Hopefully it fines up for Friday and the weekend for everyone to have a good drag meet.
https://www.sau.com.au/forums/topic/260024-compak-attak/#findComment-4470941
happy days. no yeah i will get there friday after work. aroung 5.30. lol. im to used to "normal" race meetings.. got clipsal next weekend and half our cars are still in bits.
paul, we you having me on when you said you could get me in on sunday <_< :(
https://www.sau.com.au/forums/topic/260024-compak-attak/#findComment-4471017
Dave...its only on here that i have a lend of people. Crew ticket for you is available. :P
Your hoist may be available...but hows your stock of GTR driveshafts?
Edited by DiRTgarage
https://www.sau.com.au/forums/topic/260024-compak-attak/#findComment-4471024
    • I had absolutely no symptoms whatsoever that anything was wrong.... I'm very happy it was all spotto'd and re-bled and re-torqued and aligned though. Will be picking it up tomorrow and undoubtedly be like "Oh, that clunk is gone" "Oh, the car really wants to drive straight" "Oh, that pedal feels better" "Oh, it feels like I've gained 25hp" "Oh, the handbrake works now" It should have been a sign that the new Project Mu shoes had 3mm of pad depth on them out of the box, and the OEM ones from 25 years ago that we took out also had 3mm of pad depth, implying the issue was not, and never was the shoes, but we put that down to it not being adjusted correctly. It wasn't, but it wasn't even adjustable at all given one side was boned and the T Junction of the cables was on a 45 degree angle, the non-working side being the one on the massive angle. Obviously when I had adjusted it and reset it and re-tensioned it I had either got it stuck or something along those lines. Oh well. Live and learn and absolutely could have been catastrophically worse so I'm rationalizing it as a win, kinda. I also got the chance to measure the distance between rear rim and the suspension arm/shocks and found a 30mm rubber block only just doesn't fit there. Which is great to know before ordering wheels, when I assumed 30mm was easy. The man with the Porsche adapters has rims that use 23.9mm of that space, so it's safe to assume I have between 23.9 and 29.9mm of space there to play with on the inside. The wheels looked pretty stupidly pokey with the 20mm spacers on the rear, only for me to find that the studs come out another 12mm and the wheel doesn't actually sit flush with the hub because you're supposed to cut your original studs. The wheels do have cutouts that kinda accomodate it, but not fully. So my 20mm spacer was anywhere between 25mm and 35mm. ~25mm and send it will determine on where the wheels sit with the spacers on. When I put the pads in for the track day I will mess around with spacers (with wheels that do not clear studs properly when mounted to spacers) and do more math, for the last time, for the 7th time.
    • Lucky pick up Best to find these things before something horrible happened to the yoke flange thingies I would hate to think what would happen if it dropped the tailshaft  Hopefully the holes are not flogged out in the yokes and it was just the bolts that got munted  As for the hand brake.....ouch, look like the disc got rather hot, and I assume smokey, I recall when I had a front caliper seize on the Commodore, there was lots of smoke and the disc was glowing cherry red when I was able to eventually stop and have a look, and stopping a big heavy car, going down a big hill with some rather high RPM down shifts and some hand brake action is something that makes you think hard about life
    • One of the things that never seemed right was the handbrake. Put in some nice new Project Mu shoes. We figured the rears were out, so why not. We're right there. My handbrake never worked well anyway. Well, this is them, 15km later. 67fdcf94-9763-4522-97a4-8f04b2ad0826.mp4 Keen eyes would note the difference in this picture too:   And this picture: Also, this was my Tailshaft bolts: 4ad3c7dd-51d0-4577-8e72-ba8bc82f6e87.mp4 It turns out my suspicions that one side of the handbrake cable was stretched all along were pretty accurate, as was my intuition that I didn't want to drop the tailshaft to swap them on jack stands and wasn't entirely sure about bolt torque. I have since bought the handbrake cables which have gone in. I'm very glad that I went to my mechanic friend who owns an alignment machine to get an alignment before the track day, because his eyes spotted these various levels of "WHAT THE f**k IS GOING ON HERE?". Turns out the alignment wasn't that bad, considering we changed the adjustable castor arms out for un-adjustable castor arms, and messed with the heights. Car drove pretty good with one side of the handbrake stuck on, unbleedable rear brakes, alignment screwy, and the tailshaft about to go flying and generally being a death trap waiting to happen! (I did have covid) (I maintain I adjusted the handbrake correctly, but movement caused shennanigans and/or I dislodged the spring on the problem side somewhat, or god knows what). G R E G G E D
    • Very interesting, im not sure how all those complications fit in to running a haltech instead of a stock ecu but I'm starting to think I'm a bit out of my league.
    • I just put 2 and 2 together. This is a Neo converted R32. The Neo ECU (in concert with the R34's AC controller) runs the AC quite differently to how the R32 ECU and AC controller do it. If you just drop it all in, it won't work. There is some tricky wiring required, including changing to the pressure switch that the Neo controllers want to see. I don't know what it is, because mine was done by a guru. It was a year or so after I did that transplant before he worked out what needed to be done.
