  • Replies 100
Rained stopped about an hour ago, had a solid 10mm in about 30mins along with hail and wind.
The track will be completely scrubbed of any grip, so it will come down to the mornings track prep.
Traction is over rated, Just ask Theo. :)
Had a good day all up. Car finally hooked up on the transbrake and went 11.44 @ 120.84mph. The sixty wasn't awesome - 1.73 - and there's more to come. On another note, HO-LY SHITBALLS twoogle is an animal with the big single. Wow!
what did he end up getting?
I only seen it do an 11.3XX
Sorry I didn't run into you mate, Seen everyone else though.
Also, I got the two for one deal just by asking for it - I love having an ethnic bargining background :banana:
ended up with a 10.00 @ 143 on a 9.95 dial-in in the eliminators and put Rigoli's 'Boostin' VL on the trailer. This was the only highlight in a tough day of testing and tuning the new set-up. The car was using a wheel speed cut-out for the launch control which simply didn't work. We changed to a driver operated system using a button on the steering wheel with instant success with the car turning the tyres hard off the line launching the car. Wheel spin knocked the 60' time around (1.68) so we need less boost and rpm off the line. Mark is confident my usual 1.4 60' time would have seen a 9.40 with the current power level.
The car is much harder to drive than with the low-mounts which was a simple point and shoot affair, yes 2rismo...ho-ly shitballs...this thing really moves and is such a rush to drive when it hooks up. Im going to give it another crack at a friday night ANDRA test session in 2 weeks.
big thanks to all who assisted especially Mark Jacobsen, Scott Kuhner, Dave (T04Z GTR) and the Guilt Tripper.
Edited by DiRTgarage
Yeah even the MPH on the 11 second pass was crazy.
I seen that 'wheel speed cut' kill your starts on two runs. Obviously the 10.00 was later after I left.
never got to see you run :D
you would be lucky to see 'The Guilt's' run ever...maybe only if he's late for a buffet lunch. :blink:
and i forgot to give a big thank you to 2ris' for the uplifting man love in pit lane.
Good stuff Paul and Anth... congrats on not breaking shit this time 2ris :blink:
Woulda gone but you know, stuck in bed with a woman... Unfortunately, I was still cracking better times then you lot :D
all over in 6 seconds mate?
    • Depends how low and tyre size. Should fit with natural camber, skinny tyres and rolled guards.
    • Hi guys, planning to get 18x9 +25 in fronts and 18x10 +25 in rears been reading the whole thread and cant really find anything   Anyone know if these will fit a r34 gtt with no scrubbing or guard work needed?
    • They usually get made by hand as part of any such swap.
    • Was planning on getting an R35 MAF and the adapter, should this be okay? Also any idea where I could get my hands on an intake pipe?
    • I mean yes, if you're starting from scratch on an unknown engine yes you don't need to be doing all kinds of math in the background but if you're doing relatively minor changes like AFM + injectors + boost up with some aftermarket turbos it takes quite a bit of math if you want to do something like maintain OEM fuel + timing tables but compressed and then a bit more load scale up top. I think I've spent too much time working on big engineering nightmares though so I'm a big fan of trying to constrain the scope of whatever work I'm doing as much as possible and trying to get it right before moving on. For example, a local owner just did the usual E85 + single turbo conversion to his R32 GTR and nearly burned his car to the ground doing some spirited driving up the local mountains. Turbine is unshielded and too close to the hood insulation. It's tough to balance "just get the project done" and "seemingly small details can cause massive setbacks I'm not willing to deal with".
