  • Replies 100
Rained stopped about an hour ago, had a solid 10mm in about 30mins along with hail and wind.
The track will be completely scrubbed of any grip, so it will come down to the mornings track prep.
Traction is over rated, Just ask Theo. :)
Had a good day all up. Car finally hooked up on the transbrake and went 11.44 @ 120.84mph. The sixty wasn't awesome - 1.73 - and there's more to come. On another note, HO-LY SHITBALLS twoogle is an animal with the big single. Wow!
what did he end up getting?
I only seen it do an 11.3XX
Sorry I didn't run into you mate, Seen everyone else though.
Also, I got the two for one deal just by asking for it - I love having an ethnic bargining background :banana:
ended up with a 10.00 @ 143 on a 9.95 dial-in in the eliminators and put Rigoli's 'Boostin' VL on the trailer. This was the only highlight in a tough day of testing and tuning the new set-up. The car was using a wheel speed cut-out for the launch control which simply didn't work. We changed to a driver operated system using a button on the steering wheel with instant success with the car turning the tyres hard off the line launching the car. Wheel spin knocked the 60' time around (1.68) so we need less boost and rpm off the line. Mark is confident my usual 1.4 60' time would have seen a 9.40 with the current power level.
The car is much harder to drive than with the low-mounts which was a simple point and shoot affair, yes 2rismo...ho-ly shitballs...this thing really moves and is such a rush to drive when it hooks up. Im going to give it another crack at a friday night ANDRA test session in 2 weeks.
big thanks to all who assisted especially Mark Jacobsen, Scott Kuhner, Dave (T04Z GTR) and the Guilt Tripper.
Edited by DiRTgarage
Yeah even the MPH on the 11 second pass was crazy.
I seen that 'wheel speed cut' kill your starts on two runs. Obviously the 10.00 was later after I left.
never got to see you run :D
you would be lucky to see 'The Guilt's' run ever...maybe only if he's late for a buffet lunch. :blink:
and i forgot to give a big thank you to 2ris' for the uplifting man love in pit lane.
Good stuff Paul and Anth... congrats on not breaking shit this time 2ris :blink:
Woulda gone but you know, stuck in bed with a woman... Unfortunately, I was still cracking better times then you lot :D
all over in 6 seconds mate?
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
