  • Replies 100
was a pretty good day. funny to see the grandstands empty when the v8's headed out lol..
yeah paul you car looks alot harder to drive than i would of thought. make me wonder how long it took the apc evo to get sorted lol.
and makes me want to spend more cash on my setup too :)
Spoke to Scott from Insight today and he has a new trick we can try...
Edited by 2rismo
ended up with a 10.00 @ 143 on a 9.95 dial-in in the eliminators and put Rigoli's 'Boostin' VL on the trailer. This was the only highlight in a tough day of testing and tuning the new set-up. The car was using a wheel speed cut-out for the launch control which simply didn't work. We changed to a driver operated system using a button on the steering wheel with instant success with the car turning the tyres hard off the line launching the car. Wheel spin knocked the 60' time around (1.68) so we need less boost and rpm off the line. Mark is confident my usual 1.4 60' time would have seen a 9.40 with the current power level.
The car is much harder to drive than with the low-mounts which was a simple point and shoot affair, yes 2rismo...ho-ly shitballs...this thing really moves and is such a rush to drive when it hooks up. Im going to give it another crack at a friday night ANDRA test session in 2 weeks.
big thanks to all who assisted especially Mark Jacobsen, Scott Kuhner, Dave (T04Z GTR) and the Guilt Tripper.
Good to hear you had some success, looking forward to seeing the car run its true potential now :)
Thanks for the videos mate. Much appreciated. Not exactly my best racing though. The first round was a gift and i was off it too early in the second. Archer's a great racer though and he pushed me all the way.
yeah those motec deflection sensors are spastic expencive... and the add-on amplifer box for it aswell. but, there is nothing better :)
yes i will be having a throttle kicker style real antilag. but my povo smc dont have enough outputs to run all the flatshift,antilag,launchcontol and idlespeed control all at once....
Wow! congrats on the 10.000 on your first meeting paul!
Thanks...should give it a better showing next time.
Learning how to drive again really sucks too. Or maybe i never knew...the old set-up just made it look like i knew what i was doing.
jajaja very funny but in here says that you only learn to ride bicycle one time in your life...after you been in a 8sec car never have to learn again.. have fun :P
    • Depends how low and tyre size. Should fit with natural camber, skinny tyres and rolled guards.
    • Hi guys, planning to get 18x9 +25 in fronts and 18x10 +25 in rears been reading the whole thread and cant really find anything   Anyone know if these will fit a r34 gtt with no scrubbing or guard work needed?
    • They usually get made by hand as part of any such swap.
    • Was planning on getting an R35 MAF and the adapter, should this be okay? Also any idea where I could get my hands on an intake pipe?
    • I mean yes, if you're starting from scratch on an unknown engine yes you don't need to be doing all kinds of math in the background but if you're doing relatively minor changes like AFM + injectors + boost up with some aftermarket turbos it takes quite a bit of math if you want to do something like maintain OEM fuel + timing tables but compressed and then a bit more load scale up top. I think I've spent too much time working on big engineering nightmares though so I'm a big fan of trying to constrain the scope of whatever work I'm doing as much as possible and trying to get it right before moving on. For example, a local owner just did the usual E85 + single turbo conversion to his R32 GTR and nearly burned his car to the ground doing some spirited driving up the local mountains. Turbine is unshielded and too close to the hood insulation. It's tough to balance "just get the project done" and "seemingly small details can cause massive setbacks I'm not willing to deal with".
