Before i get flamed, yes i have gone through various fuel economy threads and that is exactly why im posting up here.
Ive come across a wide range of people who claim they are getting 400-500km's per 50L (how much it typicaly takes to refill when the yellow light comes on)
Now this is quite interesting, seeing as the best ive gotten out of my tank was around 370ish and that was with granny driving and not going over 3,500 once during the whole tank. Driving rather spiritly, i get somewhere around 340ish at best..
My car is a rb25de neo r34 2door; basicly lowered, 255's at the rear, 2.5" cat-back exaust so its pretty stock, its even running a standard air box.
I am puzzled what could be causing this. Everything else in the car is working beautifully and the car is in very good nick. Idles normally at around 650-680 RPM.. Any ideas ??
Edited by r34_25GT
  • Replies 86
What tyre pressure would you guys reccomend for 255/35/18 at the rear and 225/40/18 for the front ??
Basicly, i am carrying absolutely nothing in the boot, no subs, no amps, so in general nothing that weighs the car down further. As for the checking the O2 sensor i havnt gone into doing that yet. Btw how many K's do you guys get around per tank ??
cheers
i got a 33 rb25de i get around 400km if i push it to yellow light and drive around with it on for a bit..
i use to have air panel filter than changed to a pod and actually got slightly better fuel economy =]
my car must be busted haha this is all my k's going down to approx quarter tank, never let it get much less
Idle is 900rpm when warm.
norm drivin to and from work with the occasional once every few days rev out to 5grand sees me roughly 370-390 to a tank depending if i go to penrith alot or not ie traffic.
when i was on holidays i didnt care about economy and saw close to 450 down to a quarter tank..
Highway driving to canberra got me 650 roughly using 3 quarters of a tank.
If i have the silencer in my exhaust it eats petrol on the highways.
R34 Neo 2 door manual
Mods: 3 inch kakimoto exhaust
really stiff bilsteins
Also have Sub and work boots/clothes in boot
Tyres and pressure: 225/40 R18 at 38psi.
My gauge definately isnt broken before you say anything.. Best jap tune in the world perhaps?? ;)
I've got a R34 sedan, stock standard. 35 PSI tyres.
Do quite alot of highway driving and get very close to 600 km's a tank quite frequently. NO thrashing.
If I have a heavy foot that week, I get approx 450-500 km's.
I use to get quite low milage as well. About 400-450 km's. I just gave the car a oil change, air filter and spark plugs and could see a difference immediately.
Edited by Chang
i get about 400kms per tank...............if i do hwy driving maybe another 80 or so kms.
thats with 3" exhaust, extractors, pod + a few other things aswell.....
R34 manual
idle bout 800-900rpm when reached temp
tyre pressures.........this is for 19x8 with 235's and 19x9.5 with 275's i normally do about 40psi
I WAS getting good fuel economy until I had a fualty coil pack and changed the set to some new Splitfires. Fuel economy dropped by about 80-100 km per tank :P
When these coils die, I'm putting genuine ones back in.
edit: was getting ~500km per tank around town & 600km on hwy.
Gee Scott, thats very strange about the Splitfires. I have them also and am glad they've been good to me.
I'm struggling to understand though why cold or operating temp idle rpm has any effect on overall fuel usage. the car is stationary at idle, yeah, not working/revving to propel the vehicle forwards.
Ive been noting my fuel numbers since i've had my full exhaust installed and slight timing change. I'm still averaging 500-510K's when the fuel light comes on, still averaging over 620K's to a tank and my best out of a tank is 680K's. the reason i manage such no's is because my travels is 95% highway.
1. I only found out about genuine vs. a/market coil packs "after" I installed mine. It seems there are quite a number of people who have found out that genuine coil packs are superior in every way to other direct replacements ( including Splitfire ).
2. If your cars not running right at idle ( let alone everywhere else ) you can chew up a large amount of fuel sitting there doing nothing. Usually, the indication that this is a problem is a sluggish take-off or miss-fire. Also, pronounced popping in the exhaust on low speed decel can indicate an idle fuel problem.
3. I would LOVE to see fuel consumption figures like yours ! BTW, how much did you advance your timing ?
the only real way to get a reasonably true estimate of fuel consumption is to fill up your car at a level bowser until the pump first clicks off and note the odometer reading , you can also re-set your trip meter - then drive the car till about 3/4 to near empty go back to the same bowser fill again till first click-off and record how much fuel used - this shows up on your docket usually at most petrol stations - and note the new odometer reading (which should your trip meter reading should match - then do the math using a calculator
none of this, "I drive 500k till light comes on nonsense"
my experience with a R34 GT 5 spd man NA with 4.3 diff is a best of around 9.5l/100 mixed suburban and highway/freeway when there is easy flowing traffic and no long delays with speeds up to 90 kph or so and with only occasional big bursts of acceleration
the normal result is 9.7/100k for about the same conditions -
very sadly no better result with higher speed cruising even though mostly in top gear - say Sydney to Wollongong and back - this is probably because the 4.3 ratio means you are using higher revs than are really necessary when hi speed cruising (e.g. VY Commodore cruises at 110kph at under 2000 revs whereas a R34 (4.3 ratio) uses around 3000 revs - a really stupid diff ratio only good for acceleration and crawling at idle in very heavy traffic - maybe ideal for Tokyo lol)
and there was no variation between when I had the OEM Nissan coils in or after I put in Splitfires - did I emphasise that enough????? lol again and more lol
doing the usual things like new plugs good air filter etc will help economy so will having the air con off when not essential
also you can regularly re-set your ECU (by disconnecting battery for at least 10 seconds) and this may help in certain cases
and quality of fuel may effect mileage also (no e10 pls)
9.7 l/100k is about as good as it gets for a sporty 6 cylinder car from 1998 or so weighing about 1500kg
if your only getting 13-15 l/100k average or worse then you should be concerned
I drive a R34 NA auto sedan, I tried in vain to accurately measure my fuel consumption but based on my estimates, i get around 430-450 to a tank in Melb city area...best consumption i got was 530ks when i did some highway driving
I noticed that the fuel gage is not very accurate so I noted the KMS when the fuel gage reads half full (approx 30litres).. My reading varies between 220-270 kms.
PMS ?? did I emphasise that enough????? lol again and more lol :rolleyes:
But seriously, I'm glad you've had no ill effects from "your" Splitfire coilpacks, but others have ( including myself ), and have documented it. Some big HP applications have replaced their Splitfires with new OEM coilpacks and have "gained" power.
Anyway, I can live with the fuel economy I have so long as petrol doesn't get too much more expensive.
i can get 400 out of a tank without light on and on the weekend i drove to airport and back trip is 475 km thats what i got reading at no light 1/4 of a 1/4 left highway driving u get alot more
mythbusters ahoy!
this thread is full of myths and assumptions with no facts
there is no logical way that upgrading the coils to splitfires would affect fuel econonmy that drastically
i suggest there is something fundamentally wrong, for it to go from 500kms a tank to 100kms a tank
go see a mechanic - it doesnt add up
 Share
    • There are fixes for this. In industry we use compressed air for everything. It is frequently wet, and many things cannot tolerate it. So there are various forms of driers available that you can install. The simplest option for something like this would be a dessicant drier. Much cheaper to replace some silica gel than actuator cylinders.
    • That's a solid update mate, well done at WA FOS. You may already know this, but the actuators on the paddle shift are a service item and are sadly not that reliable. As I understand it they collect water from the compressor (condensation) which then rusts the bores/pistons in the actuators. A mate of mine had no end of trouble with them in one if his circuit cars, apparently it's a 'known issue'. Buy a couple of spares at great expense to ensure you never have any problems with the ones you've got! Any clues about what the new WTAC rules might be? While faster cars are cool the Pro class arms race has got to the point where you wouldn't even bother entering without a $1m budget and even then I don't think you'd win.
    • https://nissan.epc-data.com/skyline/er34/3945-rb25det/trans/317/31940N/ The pictures of the part you're talking about is clearly not just one solenoid. You can see another picture of it here: https://www.alltranz.com.au/shop/drivetrain/automatic-transmission/RE5R01A/product/9305/ The 4 speed automatic in the GTT is Nissan corporate stuff. You can search up similar jobs done on a Frontier or Pathfinder with a RE4R01B to get an idea for what the internals are going to look like and the procedure like this:
    • Hi Chris,   long time since your post, just wondering if you have the Pinout for the v35 stereo plugs, I bought the roem nis2 harness but it doesn’t match the v35 connector. any help appreciated, I can work out the grn and power constant. But the rest might be hard. thanks Tyson
