Haven't had a chance to change the O2 sensor yet. But cleaned the TB, PCV, AFM and air box temp sensor. Idles smoother and seems to have more urge when I reach the 3000rpm mark.
The other factor that maybe contributing to bad fuel economy was my wheel alignment was way off. Had the wheels aligned this morning. Front left wheel was toed in by 3mm! It was actually visibly noticeable - I just never cared to look.
  • 4 weeks later...
  • Replies 86
  • 4 weeks later...
  • 1 month later...
  • 3 weeks later...
  • 3 weeks later...
Hi Fellas,
I'm going slightly off topic. But the car is still an N/A and a Nissan :P
Mrs. and I recently bought an N15 Pulsar 1.6L Auto sedan (granny spec??) as a our runabout/train station/shopping center/park anywhere kind of car. Car is 100% stock and has 170,000km on the clock.
I've been driving it lots lately (to work and back ~100km round trip) to get a proper grasp of the fuel economy as I've suspected the car is guzzling fuel, as we all know short trips are a bad gauge of measuring fuel economy - mainly used to go to the local train station/shops.
My route is mixed urban and freeway driving. I'm not too happy with the fuel consumption. I'm getting around 9L/100km when intentionally babying it and 10L/100km when driving "normal" (not thrashing it).
I thought this kind of car should be using around 7 to 8L/100km - being realistic, I don't believe the figures posted by Redbook (quoted combined 6.2L/100).
I've made sure tires are inflated to the correct pressure and did a an oil (Nulon Semi-Syn 10w40) and filter change. I'm currently running the car on Shell V Power every fill in the hope it will clean the engine.
Just wondering is anybody out there is having the same consumption with the same car or a car with a similar sized engine, 1.6L Auto.
For comparison purposes my Lexus IS 2.0L 6 speed manual gets 9L/100 and my R34 2.5L auto gets 11L/100, for the same route....
I realise this post is a little bit old, but what I am going to say may help others and contains some generic info. those 1.6l engines with an auto bolted to them are slugs. They are fine once they are up and moving, but take a bit to get going (I used to own a n14 version). But they should get reasonable economy as long as you aren't in stop/start economy (even then you should be in the 8 to 10l per 100kms).
I'd definitely be looking at the o2 sensor if you haven't gotten around to it yet. The other thing to check I'd how long it takes to warm up. When I got my n14 off my sister, it would sit on cold on the highway and would only come up to warm going up a hill. It was also sluggish and used more fuel than it should. I changed the thermostat and it made it run better and use less fuel. I can't remember what sort of economy I got though.
On the fuel economy front, my old daily (vt Commodore with close to 300,000kms on it) was getting about 8.7l/100kms (pretty much all highway driving). My new daily (2002 1.5l mirage with over 250,000kms on the clock) gets about 6.3l/100kms with normal highway driving. Got 5.7l out of it when babying it. Would get marginally better economy out of it on a different trip than to and from work, since there's a few hills that require dropping back a gear or 2 (one that's back to 3rd at 80kmh for just over 1km).
    • I'm seeing torque specs all over the place for the OUTER tie rod, but none for the INNER tie rod, where it connects to the steering rack. Even in videos, people are just tightening em up as much as they can with a wrench and that's it. Anything tightened down without torque makes me nervous. Anyone know what the spec is for it?
    • Hope you had a great time here in our tiny country.   The JDM scene we have here is quite small, it's mostly BMW, Volkswagen with burble tunes haha. But the few JDM cars we do have in the scene are pretty nice. Some of my friends drive cool s14's too. Both built engines, red one makes abt 500, blue one abt 400 i think?
    • Ye good idea , would have never thought of something like that. Might aswell do it to every pulley and the balancer while I’m there
    • Use an LS1 or similar, via kit like Frenchy's. But.... It's probably not the alternator. It sounds like belt squeal, which would be because the pulleys are glazed. Rub every groove on the pulleys with 120 grit paper. Report back. Oh, and new belts afterwards too. The old new ones will be shitted up already.
    • Hello all I have 2 r34 sedans , one turbo one na, only recently aquired the na 34.  Man what is with these things.... My turbo 34 started sounding like a super charger, it was screaming at anything above 4000rpm , I took the alternator apart and replaced the front bearing which is the only one I think you can access and it did not fix the issue so presumably the bearing in the rear of the alternator is gone. ( diagnosed it was the alternator by taking off the aux belts one by one to figure out which pulley or bearing it was )  My friend gave me one he had lying around, Installed it , it did not squeal for maybe 500kms and now its started to squeal again briefly on startup  Recently got an na r34 and I replaced the timing belt, water pump + all the auxillirary belts. Runs amazing but it suddenly developed the same squeaking problem but significantly worse, Ive had my neighbour come down screaming at me because it was waking her up everytime I moved the car. It takes a good 2 minutes before it quietens down.  Im yet to diagnose where its coming from but im fairly sure its coming from the alternator aswell. My question isnt about how to fix it but rather where can you get a new alternator for an rb25 neo??? Ive searched everywhere but I havent been able to find a direct fit oem type replacement thats not genuine. All the automotive stores sell an oex one - BXA035 - which I picked up for cheap through a friend with staff discount , got it home only to find the connector is completelty different.... As far as im aware bxa035 is for rb20/30's and after a bit of figuring out the bxa035 has an ev14 type connector, which is tiny compared to the rb25 connector. I actually had an ev14 connector lying around which I was considering just replacing the bigger plug with to get the alternator working but the bxa035 is rated for 70amp vs the rb25 alternators are 90amp ( or so ive been told ? ) That paired along with the fact im about to install an amp + sub in the back and I have the stock sized small battery Im not sure itll do the job unless anyone has another opinion?  I know and have seen all the websites selling the ls1 alternator conversion kit but I am not going down that route, nor do I have the money to. Hopefully I can figure out how to get 2 brand new alternators for both cars. I would buy second hand which there seems to be many of but considering how common this seems to be im sure If I installed a second hand one it would start squealing in no time  Or even better if anyone knows how to fix the issue directly with the alternator itself... Any input appreciated Thank you     Link for bxa035 connector picture
