Haven't had a chance to change the O2 sensor yet. But cleaned the TB, PCV, AFM and air box temp sensor. Idles smoother and seems to have more urge when I reach the 3000rpm mark.
The other factor that maybe contributing to bad fuel economy was my wheel alignment was way off. Had the wheels aligned this morning. Front left wheel was toed in by 3mm! It was actually visibly noticeable - I just never cared to look.
  • 4 weeks later...
  • Replies 86
  • 4 weeks later...
  • 1 month later...
  • 3 weeks later...
  • 3 weeks later...
Hi Fellas,
I'm going slightly off topic. But the car is still an N/A and a Nissan :P
Mrs. and I recently bought an N15 Pulsar 1.6L Auto sedan (granny spec??) as a our runabout/train station/shopping center/park anywhere kind of car. Car is 100% stock and has 170,000km on the clock.
I've been driving it lots lately (to work and back ~100km round trip) to get a proper grasp of the fuel economy as I've suspected the car is guzzling fuel, as we all know short trips are a bad gauge of measuring fuel economy - mainly used to go to the local train station/shops.
My route is mixed urban and freeway driving. I'm not too happy with the fuel consumption. I'm getting around 9L/100km when intentionally babying it and 10L/100km when driving "normal" (not thrashing it).
I thought this kind of car should be using around 7 to 8L/100km - being realistic, I don't believe the figures posted by Redbook (quoted combined 6.2L/100).
I've made sure tires are inflated to the correct pressure and did a an oil (Nulon Semi-Syn 10w40) and filter change. I'm currently running the car on Shell V Power every fill in the hope it will clean the engine.
Just wondering is anybody out there is having the same consumption with the same car or a car with a similar sized engine, 1.6L Auto.
For comparison purposes my Lexus IS 2.0L 6 speed manual gets 9L/100 and my R34 2.5L auto gets 11L/100, for the same route....
I realise this post is a little bit old, but what I am going to say may help others and contains some generic info. those 1.6l engines with an auto bolted to them are slugs. They are fine once they are up and moving, but take a bit to get going (I used to own a n14 version). But they should get reasonable economy as long as you aren't in stop/start economy (even then you should be in the 8 to 10l per 100kms).
I'd definitely be looking at the o2 sensor if you haven't gotten around to it yet. The other thing to check I'd how long it takes to warm up. When I got my n14 off my sister, it would sit on cold on the highway and would only come up to warm going up a hill. It was also sluggish and used more fuel than it should. I changed the thermostat and it made it run better and use less fuel. I can't remember what sort of economy I got though.
On the fuel economy front, my old daily (vt Commodore with close to 300,000kms on it) was getting about 8.7l/100kms (pretty much all highway driving). My new daily (2002 1.5l mirage with over 250,000kms on the clock) gets about 6.3l/100kms with normal highway driving. Got 5.7l out of it when babying it. Would get marginally better economy out of it on a different trip than to and from work, since there's a few hills that require dropping back a gear or 2 (one that's back to 3rd at 80kmh for just over 1km).
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
