Hi Guys,
My car is running fine but id love to get no error codes. Just because we can...
So im trying to fix this error code 21 (ignition system). Refering to the guide and performing its required tests here are my results... can anyone help me come to a clear conclusion?
This could be a good reference for future skyline riders who get this error.
Just Before i begin ive noticed in the skyline manual it says the ignitor harness should be 1,2,3,4,5,6,G ... however mine is 1,2,3,G,4,5,6 I hope thats normal in australian skylines or has the previous owner done something custom.
TEST ONE - Remove each connector to the coils/spark plugs to see if rev changes.
This test passed, all connectors made an impact to rpms.
TEST TWO - On the Ignitor harness check continuity between terminal E and Earth.
Passed.
TEST THREE - Test continuity between certain ecu terminals and ignitor connectors.
CONFUSED:::: Why are these results ended up this way, is this normal??Could this be a cause???
Check ECU terminal ->(conects to)-> Ignitor Terminal | RESULT: ECU TERMINAL ->(was actually connected to)-> Ignitor Terminal
1 -> 2 | 1 -> 1 (good connection)
12 ->2 | 12 -> 5 (good connection)
3 -> 3 | 3 -> 3 (good connection)
13 -> 4 | 13 -> 6 (good connection)
2 -> 5 | 2 -> 2 (good connection)
11 -> 6 | 11 -> 4 (good connection)
10 -> E | 10 -> E (flakey, connection wasnt showing 100% continuity)
20 -> E | 10 -> E (good connection)
CONCLUSION: ??
TEST FOUR: Check voltages of ecu terminals below with a group point on idle it is expected to be aprox 0.2V~0.3V.
Terminals: 1,2,3,11,12,13 all showed 0.07V~0.08V on idle.
Ive then also noted this wire loose which seems to be sticking out of the the connection leading to the furthest (from front of car) spark plug.
I also noticed the wire below (black/purlple) just loops,is that normal?:
So is anyone able to help on this one?
Edited by rnbguy
https://www.sau.com.au/forums/topic/260063-error-code-21-diagnosed-results/
The black wire with broken connector on the end is meant to be earthed. Crimp a new connector on the end and earth it to the rocker cover with a coil pack cover screw. The loop in the harness is used for checking timing and is normal.
Edited by nIsMo86
123456g is a rb 20 ignitor, 123g456 is a s1 rb25 ignitor
thanx for clearing that up, ive noticed a few typos in the manual because that pattern was written to be for a rb25det.... so why does the guide say ecu pin 1 (inj 1) is supposed to goto pin 2 on the ignitor (im guessing meaning cyl 2) when in mine actually ends up ecu 1 goes to ignitor 1?
and same with the rest mentioned above?
do not forget that Code 21 can be an intermittent fault - at start, later it becomes somewhat permanent as the coil(s) breakdown more - so you may get good readings during testing even though you may be following correct procedure
if the coilpacks are oem Nissan and have done about 60k+ already you may as well just get new set of Splitfires and be done
thanx for the tips guys, grounding that black wire pictured above fixed the issue 21 from comming back up and at the same time fixed the not so well result above of the Earth to pin 10....
I'll still be curious why the ecu injectors are pointing to different points on the ignitor.
    • I had absolutely no symptoms whatsoever that anything was wrong.... I'm very happy it was all spotto'd and re-bled and re-torqued and aligned though. Will be picking it up tomorrow and undoubtedly be like "Oh, that clunk is gone" "Oh, the car really wants to drive straight" "Oh, that pedal feels better" "Oh, it feels like I've gained 25hp" "Oh, the handbrake works now" It should have been a sign that the new Project Mu shoes had 3mm of pad depth on them out of the box, and the OEM ones from 25 years ago that we took out also had 3mm of pad depth, implying the issue was not, and never was the shoes, but we put that down to it not being adjusted correctly. It wasn't, but it wasn't even adjustable at all given one side was boned and the T Junction of the cables was on a 45 degree angle, the non-working side being the one on the massive angle. Obviously when I had adjusted it and reset it and re-tensioned it I had either got it stuck or something along those lines. Oh well. Live and learn and absolutely could have been catastrophically worse so I'm rationalizing it as a win, kinda. I also got the chance to measure the distance between rear rim and the suspension arm/shocks and found a 30mm rubber block only just doesn't fit there. Which is great to know before ordering wheels, when I assumed 30mm was easy. The man with the Porsche adapters has rims that use 23.9mm of that space, so it's safe to assume I have between 23.9 and 29.9mm of space there to play with on the inside. The wheels looked pretty stupidly pokey with the 20mm spacers on the rear, only for me to find that the studs come out another 12mm and the wheel doesn't actually sit flush with the hub because you're supposed to cut your original studs. The wheels do have cutouts that kinda accomodate it, but not fully. So my 20mm spacer was anywhere between 25mm and 35mm. ~25mm and send it will determine on where the wheels sit with the spacers on. When I put the pads in for the track day I will mess around with spacers (with wheels that do not clear studs properly when mounted to spacers) and do more math, for the last time, for the 7th time.
    • Lucky pick up Best to find these things before something horrible happened to the yoke flange thingies I would hate to think what would happen if it dropped the tailshaft  Hopefully the holes are not flogged out in the yokes and it was just the bolts that got munted  As for the hand brake.....ouch, look like the disc got rather hot, and I assume smokey, I recall when I had a front caliper seize on the Commodore, there was lots of smoke and the disc was glowing cherry red when I was able to eventually stop and have a look, and stopping a big heavy car, going down a big hill with some rather high RPM down shifts and some hand brake action is something that makes you think hard about life
    • One of the things that never seemed right was the handbrake. Put in some nice new Project Mu shoes. We figured the rears were out, so why not. We're right there. My handbrake never worked well anyway. Well, this is them, 15km later. 67fdcf94-9763-4522-97a4-8f04b2ad0826.mp4 Keen eyes would note the difference in this picture too:   And this picture: Also, this was my Tailshaft bolts: 4ad3c7dd-51d0-4577-8e72-ba8bc82f6e87.mp4 It turns out my suspicions that one side of the handbrake cable was stretched all along were pretty accurate, as was my intuition that I didn't want to drop the tailshaft to swap them on jack stands and wasn't entirely sure about bolt torque. I have since bought the handbrake cables which have gone in. I'm very glad that I went to my mechanic friend who owns an alignment machine to get an alignment before the track day, because his eyes spotted these various levels of "WHAT THE f**k IS GOING ON HERE?". Turns out the alignment wasn't that bad, considering we changed the adjustable castor arms out for un-adjustable castor arms, and messed with the heights. Car drove pretty good with one side of the handbrake stuck on, unbleedable rear brakes, alignment screwy, and the tailshaft about to go flying and generally being a death trap waiting to happen! (I did have covid) (I maintain I adjusted the handbrake correctly, but movement caused shennanigans and/or I dislodged the spring on the problem side somewhat, or god knows what). G R E G G E D
    • Very interesting, im not sure how all those complications fit in to running a haltech instead of a stock ecu but I'm starting to think I'm a bit out of my league.
    • I just put 2 and 2 together. This is a Neo converted R32. The Neo ECU (in concert with the R34's AC controller) runs the AC quite differently to how the R32 ECU and AC controller do it. If you just drop it all in, it won't work. There is some tricky wiring required, including changing to the pressure switch that the Neo controllers want to see. I don't know what it is, because mine was done by a guru. It was a year or so after I did that transplant before he worked out what needed to be done.
