huh? that's wierd, if boost increased when you made an exhaust change, wouldnt this indicate more of a restriction?
that is, the backpressure can't escape quick enough, which drives the exhaust wheel faster, which drives the compressor wheel faster, which increases boost in the intake side without any change
Other way around.
  • Replies 40
Posted Images
i've got a full exhaust on my GTR
Mines Dump Pipes
aftermarket front pipe (Stainless)
hi flow cat(stainless)
3in stainless cat back with oval muffler
the dump pipes arent needed, i only did mine cos i changed the turbos, and though "may as well"
just get a aftermarket brand front pipe, good hi flow cat and ring around a few exhaust shops and get them to do a cat back.
i didnt really worry about which brand to use, its all just metal, and just as long as its all mendrel bent youre fine.
and when it comes to sound if youre that picky, try and find a muffler that will give you the note you want, and if you need you can always chuck a hotdog in to deepen the note if need be.
good luck mate,
i'm sure youre gonna like what you get, i know i love the sound of my exhaust!
Brezza
At the moment im running Tomei manifolds, HKS dumps, HKS front pipes 3.5 inch cat and a Kakimoto Full mega N1. Pretty damn quiet at the lights and driving.. NO drone what so ever. On boost... My god what a noise!!! I couldnt believe how much difference the cat back has made. I had some 3 inch "cut and shut" system on their before.... Just with the catback change i reckon its going better on 1.3 bar with timing pulled out of it then it was on 1.7 (2.8 stroker twin GT RS's). However it wont be cheap as previously said :P
Hey guys, on this subject, I have a GTR with a pair of 2860's, with CES split dumps to Y-pipe to 3.5" hi-flow metal cat. Basically my old exhaust (unknown brand, 3") was reflanged to fit the cat.. What would you guys suggest I get? I'm past my "run in" stage on my new motor, so I need to get my final tune done.
Thanks for your suggestions! :D
Kakimoto Regu 06+R or the Full mega N1
Paul
Man your idea of not loud must be way different to mine or some how the top part of my system must do some nasty damage. I have the Full Mega N1 (single pipe not twin) and without the additional baffle pipe in the cannon (inner silencer) it is a cop magnet - loud and on boost I agree awesome but really loud. Top part is a custom 3" bell mouths off turbs to 3.5" collector to 4" metalcat to N1.
Cheers
Well when i bought the system i was pretty worried about how loud it was going to be at idle and say sub 3500 RPM. Started the car and it just purs. Ive had a mate drive next to me and he said he can hardly hear anything. On boost it absolutely SCREAMS but without big revs adnd the gates not open its quiet as.
  • 4 weeks later...
Hi, know nothing about exhausts. Am going to look at one tomorrow.. XForce apparently 3" to cat (xforce cat?) and 4" rest of the way + full stainless. Its at a good price so I'm pretty much sold on it unless someone can tell me different? (To suit GTR33)
Also, is it going to loud as hell?
Cheers guys.
Edited by Ten Four
Can someone confirm before I go and buy it please...?
4" from cat back will be pretty loud, I have a Trust Power Evolution 2 (94mm but close enough to 4") and it is pretty loud, you will get defected.
Depends if it is 4" with a few decent mufflers in there to be under the dB limit?
Cheers, dont have much info atm, just what i said above. I'd be going to buy it today but haven't got a ute atm... Getting it tomorrow in a hatchback :rofl2:
I would find out a bit more info before you commit and hand over cash!
380kw has been made on stock 33 GTR dumps with 2560 turbos.
Im changing back to standard GTR dumps because my stainless HKS split dumps are giving me creep. Also running 2560s.
Im also running a HKS Dual Racing Exhaust, its a full twin which never joins. Tuned length dual.
By changing from a single 3.7 HKS Super Dragger to this exhaust, boost shot up to 23psi from 17psi with no other changes! Let me say it must flow very well!!!
I have R33 GTR Dumps for sale if you need them, the R32 ones are crap.
P.S CES have the worst customer service in the world! dont bother with them!
Was the twin system much/any louder than the single?
I am looking at changing from single to twin system possibly.
It's also apparently 2 months old. I'm mainly going for it cause its only $250 and its all xforce. I had thought 3.5" was the max one should run. Will 4" be unbearably loud cause this is a daily driver...
I rekon twin systems are the bees knees. if you have one direct exhaust path for each turbo it will not only help flow issues but it gives you more room under the car!!!
I agree, with the first bit. But I think you will find there is less room under car, perhaps slightly more clearance to the ground which is what I think you mean.
When I get to the point of upgrading turbos twin 3" all the way to the back of the car... wooohooo!!!!
"Ten Four" for $250 you can't really go wrong, buy it, fit it, if it is too loud for your liking then f**k it off for something more suitable.
Cheers mate, bought and collected it today (had a dent so i got it for $150 lol). It's basically a complete xforce system inc cat. Has middle muffler and rear. Question: Will the whole lot bolt up to stock front pipes or do I need to get some to suit? (Last question and very thankful cheers.)
Here's a awesome paint diagram to help explain..
Edited by Ten Four
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
